22re engine ground
22re engine ground
Were about is the engine ground at on a 22re? I hvae check engine code 25! So Im starting with the easy stuff first! So if you know were the engine ground it please let me know! Thanks, 94toy4x4fever
ok forget about the ground or code 25! I read the flashes wrong! Its code 52! Whitch is the knock sensor. Is this sensor right close to the oil filter on a 22re? I know how to test it just not to sure on where to find it! Thanks guys bear with me here
Yeah I do know! Remove knock sensor. The using an ohm meter make sure there is no continuity between the terminal and the body of the sensor. If there is replace the sensor! How do you like them apples! And yes I have know what a oscilloscope is and have used one!
A knock sensor generates a voltage when it is "shocked" by knock ping ect... What else more do you need to know. Or mabye you know a little more than I do. Seems to me like you know everthing just my 2 cents
given your description "a knock sensor generates a voltage then it is 'shocked' by knock, ping etc.", you can't determine if it is good or bad by, as you said: "using an ohm meter make sure there is no continuity between the terminal and the body of the sensor"
one with some background in electronics would tell you that your 'test' procedure is analogous to testing a microphone for frequency response by measuring its resistance.... and they won't tell you that because it is wrong...
and why I asked if you had an oscilloscope.
And the original question was:
"Were about is the engine ground at on a 22re? I hvae check engine code 25! So Im starting with the easy stuff first! So if you know were the engine ground it please let me know! Thanks, 94toy4x4fever"
And... I guess you didn't read I'm 38 and have designed and/or have modified electrical systems on RV's between 1993 to 1995.... I have worked on and modified electrical systems for 'cell-phone' and other 'wireless' towers from 1995 and up to and including today- I'll be boarding a a plane in about 8 hours to take me to work on several 'mediaflo' sites.
A few years ago IBEW made me an 'apprentice' and 2 weeks later awarded me 'journeyman' status. I quit the union and they keep sending me shiznit to get me to re-associate myself with them.
...and you haven't even mentioned "piezo-electric" yet.
"22re + knock sensor"
