22RE Coolant hose identification
Old Dec 8, 2012 | 12:34 AM
combatcarl's Avatar
Good enough shot for me! I'm gonna have to do that, want a cs144 swap, it'll open up a butt load of space. Looks good, thanks, man! Hijack off!
Old Dec 8, 2012 | 07:40 AM
Terrys87's Avatar
I use Gates Rubber hose PN# 20801, around $10. It comes is a "S" shaped form, but when you cut the lower part off, it looks identical to the original and has the larger opening coming off of the water pump and the smaller end for the horseshoe pipe.
Gates PN#20801, just cut off where my finger is at. Alot cheaper then the dealer.
Here it is cut to length and on. I need to get some new hose clamps to finish the job.
Old Dec 8, 2012 | 01:57 PM
Turd Furgeson's Avatar
There is of course a little trimming of the water pump hose,but I'm sure you can figure that out. I didn't even trim the part of the silicone hose that goes on the steel pipe. I just slid the steel pipe into the silicone hose all the way to the 90* in the silicone hose and put the clamp on it. I think I had to trim a little off the part that goes on the bottom radiator neck. What's a cs144 swap?
Old Oct 23, 2015 | 04:15 AM
Obmi's Avatar
Originally Posted by abecedarian
The one from the lower rad to the pipe should be Dayco B78015, and from the pipe to the water pump should be Dayco B71383.
The one from the thermostat to the upper radiator should be Dayco C71262.
The "pipe" is a hard part not available from the aftermarket, that I know of, so would have to come from the dealer or salvage.
You just saved my butt. Thanks
Old Oct 23, 2015 | 10:59 PM
  #25
anndel's Avatar
When I did my timing chain, I went with Gates from O'Reilly. The radiator was changed 2 years ago with the upper and lower radiator to pipe hose but since I was replacing the timing chain, water pump, etc., I went with new hoses as well. You don't need OEM Toyota hoses and like others mentioned, Dayco, Gates, Goodyear, AC Delco, etc., are great replacements.
the1998sr5
15
Jul 14, 2020 08:35 PM
94 Newbie
Aug 6, 2015 10:33 AM
Logz808
Jul 26, 2015 07:09 AM
jjrbus
Jul 23, 2015 05:05 PM
Poncho0206
Jul 10, 2015 06:21 PM
