22re block HELP!!!!!
Ok... i need help bad. I went to put new headers on, and the last bolt(top) in the very rear is cross threaded in the block. It sits flush and fine... except where that bolt is... Now i have an exhaust leak... and i need to fix this.. im 17 and dont have many tools... how can i... or what should i do to correct this.
any help... thanks
any help... thanks
1:38 AM? Wow. On my 94, the exaust manifold has studs and nuts, not bolts. Does your header attach with bolts? If studs, is the stud cross threaded into the block or is the nut cross threaded? If it is the nut, you can replace it. If the nut end of the stud, you can replace the stud, though you may have to remove the header and or use a pipe wrench to get the stud off.
Try putting in a longer bolt. I have had this problem with the same hole on two trucks now. I just put a longer bolt in as the threads are still good deep in the hole. I have also put in a different thread (course) bolt and took it easy. It is an Aluminum head so it is easy to strip but also easy to cut new threads with a bolt
