22R hard to start
Old Dec 27, 2012 | 03:24 AM
Aus_Lux's Avatar
22R hard to start
Hi there,
1995 RN105 4x4 single cab 22R petrol
I've recently had my carb rebuilt and when I first got the car back from the garage, it would start first go. Nowadays, I need to pump the accelerator atleast 8 times before it will start. If I don't pump at all, then there is no chance of it starting. I've had the carb rebuilt, new plugs, new fan belts, rotor etc
Any ideas on what could be causing this? Lack of fuel getting to carb?
Any help would be highly appreciated
Cheers.
Old Dec 27, 2012 | 05:54 AM
junkyardog05's Avatar
I would check my accelerator pump and also check the tube that runs from it.
Old Dec 27, 2012 | 06:37 AM
bruzer's Avatar
Is the choke working?
Old Dec 27, 2012 | 11:19 AM
slow-mo's Avatar
This is actually a common scenario after a caburetor rebuild.
The fuel in the float bowl will drain out, into the intake manifold, after the vehicle has been sitting awhile or overnight. When the fuel drains out, the engine takes longer to start because the mechanical fuel pump has to first pump fuel into the carburetor at the correct level. After this, then there will be enough gas so that when you pump the gas pedal, fuel will squirt into the carburetor to start the engine.
Check was the others have mentioned already.
Also check the fuel level in the float bowl on the next cold engine start via the sight glass. It is supposed to be in the middle. You can wiggle the front end up and down to see if the fuel sloshes around the sight glass.
Old Dec 27, 2012 | 05:00 PM
TrikeKid's Avatar
You had the carb rebuilt at a shop? How long ago? Not sure how stuff works down under but I'd be back at the shop having them fix their rebuild. Is the choke working?
Old Dec 29, 2012 | 07:11 PM
Aus_Lux's Avatar
Yes, was rebuilt at a local mechanic shop. I'll be seeing them next year hopefully.
I checked the float bowl level this morning and there was no fuel inside (car was not driven for a day or two)
Sorry if this sounds stupid, but how do I check if the choke is working?
Thanks for all the help so far
Old Dec 30, 2012 | 07:40 PM
TrikeKid's Avatar
If you remove the air cleaner you should see the choke flaps closed over the top of the carb (tap the pedal once first and they should flip shut), then start the truck and let it warm up, they should move and allow full air flow and a normal idle.
Old Dec 31, 2012 | 03:02 PM
Aus_Lux's Avatar
Alright, will give that a go. How do I go about fixing the excessive pumps which is required to start it? I'm guessing the choke isn't doing it's thing and that's why there's no fuel in the fuel bowl the next day?
Old Dec 31, 2012 | 03:34 PM
timothy47129's Avatar
It sounds like you are in the same boat im in with the carb leaking into the intake over night.theres some good info on it if you do a search wont start 1st start of the day and here we go again 1989 toyota floods.I have rebuilt mine 2x and the same thing happens.look at the sight glass 1st thing before you try to start it and see if its dry then.hopefully this will be of some help to you
Old Jan 2, 2013 | 04:35 AM
Aus_Lux's Avatar
I read through both your threads mate and will be replacing the gaskets that are leaking as I had a look at my carb earlier and there appears to be a small leak from the base of it.
Every morning when I look through the sight glass, it is completely dry and empty. Then comes the daily ritual of 8-10 pumps to start it..
Did you find a solid fix at all for your truck?
Old Jan 2, 2013 | 05:07 AM
No still working on it have a new not rebuilt carb made in china on the way we will see how that goes here in a few weeks.i think I'm going to get some fuel system dye and pour it in the fuel bowl and let it sit overnight and use a uv light in the morning to try to see were its leaking
Old Jan 2, 2013 | 02:03 PM
Aus_Lux's Avatar
No worries. Let me know how you go with it all. Hopefully someone has a fix for our issue
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
