22r backfire
22r backfire
My 87 has a horrid backfire when I let off the pedal to shift. I have reset the mixture screw, timed it, checked the vac lines and I still can't seem to figure out what might be causing it.
I put a junkyard motor in it about a month ago. But it backfired before that. We did the timing right after. I had some vac lines reversed but they are all straight now. The plugs are relativley new along with the wires. It backfires thru the exhaust. Shoots flames like camo said his did. It also smells like its dumping raw gasoline out the turndown.
sounds like the aap diaphram is busted. pull the vac line off it and see if fuel dumps out of it. This might only affect the engine if it's cold but not warm As the vacuum to that is controlled by a bvsv.
only other thing I can think of is a sicking float.
same carb as the old motor right?
how are your mufflers and cat? also are u sure that the carb is not dumping gas in still after u let off the pedal? my 87 use to pop due to me putting an after market cap and muffler on that where high flow. not enough back pressure i guess or something..
They are both old. The muffler has a split from backfiring and im pretty sure the cat is the original, all in its 415XXX mile glory. Im sure that has something to do with it. The carb is not dumping fuel still after I let off of the gas. It ran 100% on the other truck.
