1UZ swap exhaust manifold/header fitment
Old Jun 10, 2013 | 05:40 PM
jmswltn's Avatar
Im starting the 1uzfe swap into my 2nd gen 4runner but can't find clear answers anywhere as to which headers manifolds will work with ifs.
I have both sc400 and ls400 engines with manifolds but have read that the flanges hit the frame rails.
I've also heard of using tundra manifolds, or aftermarket tundra headers with the flange moved farther back down?
Does anyone have a real answer/solution to this?
yes I am familiar with the search bar
Old Aug 6, 2013 | 09:47 PM
ChefYota4x4's Avatar
I'm watchin..... I know RMA worked this stuff out.....but thats first gen..... Hmmmm. Oh, Shaggy is a 2nd gen that got it sussed I think..... Maybe another guy named Vance... I will see if I can find them and post up what I can.
Best to ya man.... Timing kit and manifold work and all!
Old Aug 8, 2013 | 06:19 AM
jmswltn's Avatar
For Now I'm Going To Extend The Ls Manifold As Its Not Stainless
Old Aug 8, 2013 | 08:19 AM
Gsolo's Avatar
If I remember correctly the LS manifolds are the most "compact". I've heard of the tundra manifolds working but havent seen them. The factory tundra manifolds are kinda crude log style...and very prone to cracking
Old Aug 8, 2013 | 10:30 PM
85toyman's Avatar
I have the 1uz in my 94 runner. I have a build page here as well.
The best solution is to use tundra manifolds from a 2000 thru 2002. You will need to cut the collector off and weld some smaller flanges off. Then they fit like butter.
I do know the pipe diameter is much smaller then the ls units. I think I might play with mine later and see how much of a difference they make, but this will get you going and work well
Old Aug 8, 2013 | 10:32 PM
85toyman's Avatar
If ya need parts let me know I have another SC motor and some more ls stuff too. I build motor mounts and a new aluminum radiator for this application as well
Old Aug 13, 2013 | 07:01 AM
jmswltn's Avatar
how much are we talking for a radiator shipped to ohio
Old Aug 13, 2013 | 07:35 AM
85toyman's Avatar
I am on vacation so I can't get you an exact quote, but we will be in the $500 range shipped.
Old Aug 22, 2013 | 10:16 AM
jmswltn's Avatar
here is the ls manifolds cut and cleaned up for welding. i cut off the flange for the egr i will be welding a patch panel over it.
i haven't decided on my coupling devices be it flange or slip fitting, im more leaning toward the slip fitting i already have.
I need to get the trans mounted to the engine to set up the crossover pipe.
RatOmeter
Oct 22, 2015 03:17 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
Coreyr384
Jul 10, 2015 11:13 AM
