1st Gen 4Runner ZUK Mod DIY/How to (Lots 'o' photos!)
Old Apr 22, 2011 | 06:15 AM
  #101
92 TOY's Avatar
Originally Posted by c0ugar69
I have the 14"x100lb springs in mine and its great. I did cut them down a bit because the lift was too much to level with the torsions. I probably could have went with the 12"x125lb and been good. I have mine mounted with upper bump stop cut and opened enough to slide the spring in. I have flexed mine out a number of times and have not had any problems with springs even getting close to coming out. Info is in my build thread. I highly recommend the ZUK mod if your looking for a cheaper fix than replacing with new leafs.
the 12 x 125 is what I intend to use on the 4runner and likely mine as well.
you also addressed my concern of flex.....and alleviated my concern as well.
tanx.....looking forward to doing this.
Old Apr 27, 2011 | 08:36 PM
  #102
kbrashears's Avatar
A little cut, a little persuasion, and a little hammering (hey, just like my wedding night!) I did a zuk mod tonight to my 87 pickup. Put in 12 in 125 lb coils and man, what a difference. It was like I gave my truck a tummy tuck, rear lift, boob job, and a facelift! I swear she was running better tonight. The ride was incredible. The truck is much better, too!
Old Apr 27, 2011 | 10:41 PM
  #103
ZUK's Avatar
ZUK
kbrashears, thanks for posting up
Old Apr 29, 2011 | 06:09 AM
  #104
polycrack's Avatar
spring mod w struts springs from passenger car
tryed this mod with some springs I found that were from some rear struts from a passenger car. Its nice and level now and does flex good, but rides stiff. if you hit a speed bump hard the front rolls over it and the back bounces up in the air a bit. chk it out
crushed
down
Old Apr 29, 2011 | 07:21 AM
  #105
ZUK's Avatar
ZUK
It looks like it's secured enough so that it won't go nowhere. How much lift did they give? The lower fit over the rubber snubbers could cause an issue farther down the road. Certainly is good for the testing you're doing though.
And if you could measure the outside diameter it would be appreciated....5"?
Old Apr 29, 2011 | 09:10 AM
  #106
polycrack's Avatar
I put the blazeland kit up front, so that lifted it 2/3" and i put some shackels in the rear 7" from bolt to bolt and its about level maybe 1/2" more in the rear.
outside dia is 4.5"
the leafs were on the overloads before the coil springs. I think the shocks are limiting the drop limit, gonna chk it out today.
Old Apr 29, 2011 | 09:31 AM
  #107
ZUK's Avatar
ZUK
thanks....I was wondering if 5" OD coils were the ones I've seen others use that slip over top steel stopper so much...but based on you using 4.5", I'd say that 5" wouldn't fit over either. Probably 5.5" inchers would though.
I'm figuring a stiffer ride could result if the coils were a heavier poundage like 200 lb/ inch rated (obviously).....also, it could ride stiffer if the coils didn't lift it very much....say a 1 inch lift.....and that means the coils are adding in with the leafs for a total pounds/inch that is closer to about 300.
Stiff shocks could also do that.
Old Jul 28, 2011 | 01:06 PM
  #108
1985runner's Avatar
Does anyone know if its possible to use the jeep TJ coils up front on a solid axle 4runner? I have a very clean 85 4runner and i want to keep it as stock as possible.
Old Aug 1, 2011 | 10:00 PM
  #109
ChefYota4x4's Avatar
Hey Philbert! Hope you're well, buddy!
Just a couple pics for reference..... 600# in the very rear for my trip to Havasu(some in the back seats as well, but not much)...... 12"x125# coils on what was OVER FLAT spring pack and riding on the bump stops... with all the weight and on a hill in both pics, ....maybeeeeee dropped .5-.75",.......600#..... LOVE the Zuks, especially when I need em, ya know? Pics, both loaded with the 600#(plus, actually, just being fair)>>>>>>>>
Old Aug 1, 2011 | 10:38 PM
  #110
Philbert's Avatar
Doing great, Chef, thanks!
Just got back from driving the beast up to Portland and back down here....I think around 1300 miles but not sure Still loving my ZUK spring mod, but dream of Chevys one day.....
Old Aug 2, 2011 | 02:39 AM
  #111
Stag's Avatar
Chef that's a super clean runner. I'm a big fan of the zuk mod myself. Thanks to philberts in depth posts. Made my install easy. Just waiting now to buy balljoint spacers for the front to level out my runner. Did you by new shocks for the rear after the zuk mod?
Old Aug 2, 2011 | 08:05 AM
  #112
RIGHT ON, PHIL! Great to hear from ya..... was wondering if you'd taken a leave from Yotatech for a bit or something, lol. I have had to lately, just so busy! lol.
Hey Stag,.... thanks, man! Means a lot....it's all been worth it. Far as the shocks, I did NOT replace mine....but then, I started with shocks for a 4" lifted Pick up(my buddy gave these to me, they're Rancho RS5000's....... LILLLLLLLLLLL stiff, to say the least). I think they also are different in extended/compressed from what I need, but bottom line, they're long enough to make up for the added lift with the Zuk.
Like I said, I'm LOADED, and I mean heavy....and it's just barely compressing these springs! Plus, the ride, with a lil weight, is even nicer(at least on the 12"x125#'ers)
Take care, guys,..... TRAVELING MERCIES TO ALL YA'ALL!
Old Aug 8, 2011 | 02:44 AM
  #113
92 TOY's Avatar
hmmmmm....me thinks this needs to be done soon on Joe's.
Old Aug 14, 2011 | 11:14 AM
  #114
edeslaur's Avatar
My mod is nearly done.
For those who sub'd to my thread, please let me know if you're still getting updates via email? I seem to be the only one posting to it lately, that's atypical. Maybe I'm just ultra-boring?
Here's the before - stock height, no mod. There was about 2" between the rear bumpstops. I had a pic, but... details in the link.
Here's the after - Blazeland long travel (appx 3" lift) and 14", 125# springs
The ride is awesome all around. It's a new truck.
Speed humps that caused a bang and a ruckus now are hardly noticeable at 12-14mph more, even with a load of crap in the back (33" spare, axles, couple cases of water, tools, and more junk) .
The rear tops out when going fast enough, it's going to need longer shackles to resolve that.
Here's the 'Zuk post of my buildup thread:
https://www.yotatech.com/forums/f116...l#post51769934
I almost scored a set of AllPro 5" leafs for $150, but I just missed them so I ended up still installing these.
It's a great mod. The price point makes it even more awesome!!
Old Aug 14, 2011 | 04:46 PM
  #115
Philbert's Avatar
Looks great!
Old Aug 14, 2011 | 05:32 PM
  #116
Hey Phil! Sup brotha!?!?!?
Got some shots while wheeling in Havasu.... think I already posted em in my build, Zuk Thread, etc. Not here yet... But since I got some today, testing a lil flex on a big tree root, shot with my cell... I thought I'd torture everyone with the terrible pic quality! hahaha.
Here is the ones while wheeling in Havasu, AZ....
Up, up and over>>>
All of this made possible, in part by this mod!(not to deny the importance of the new gears and rear locker, but you get my point! lol. I'd have bottomed out ALL OVER!)
Now, these were today, just to show, not even fully stuffed on the driver side/flexing droop on the passenger side.... they STILL are clearly working, not becoming dangerous(about to drop out the tower, etc.)... and, well, they are DOING they're job! The other couple pics are not even close to the limits of front end stuffs, but showing, clearly, that the Mega Travel Ball Joints, BJ spacer lift/suspension restore has worked wonders... Before, I couldn't get near there without getting the front driver side tire off the ground... now most of it is on the ground, even with 8" Up from level on the passenger side, at least. Like I said, could have stuffed more, but ran out of tree! .... and time, of course! lol. Some pics>>>
Just my Humble Opinion... THESE ARE A GREAT SOLUTION TO SAG! Secondly, you can see, they don't stop all practical wheeling/applications! PLUS, .....the loads I can carry without bottoming out is astounding!!!!
BTW, these are the 12"x125# with 1.5" 4Crawler BJ spacer lift and Downey Mega Travel Upper BJ's, New, as well as New OEM Lower BJ's, new CA bushings, and some shocks a great guy GAVE me(yotatech homie and now homie in general! lol Anthony1 on here).
Old Aug 15, 2011 | 08:26 AM
  #117
Philbert's Avatar
Hey Chef - good to see you're out using that thing!
And man, those ARE terrible photos, thanks for the torture
Old Aug 15, 2011 | 11:59 AM
  #118
Oh c'monnnnnnnn! lol. I was hoping you'd say, "Oh c'mon, they're not that bad, ...seen worse"... something like that! hahahaha. Jk.... and thanks, VERY MUCH... I'm enjoying it to BLISS! lol. Getting my alarm guy to do some crazy stuff soon.... Unfortunately, because of trolling THIEVES in L.A..... yeah, can't really share unless on the phone, hahaha.
Anyway, I'll get better pics when I bring the actual Camera, next time, k?
Old Aug 15, 2011 | 12:45 PM
  #119
Philbert's Avatar
Hey that was a softball lob....had to take a swing.
I've gone through 2 dedicated "shop" digital cameras...I'm a klutz, so most of my project pics are from my phone these days....you just need a better phone
Glad to see you're loving them! Mine are good but I still want to do the Chevy (or F150) swap one of these days....now that I finally took a welding class and have (some) idea how to do this!
Old Aug 15, 2011 | 01:27 PM
  #120
Hahaha... I know, just messin!
Wow, I messed my point and shoot up too... but still works. Just can't always have it.... since, well, IT'S THERE'S! lol. I have a Canon-D... but no WAY am I leaving that in the car on a 2-3 hour 'errand' trip, ya know? lol. yeah, that bothered me, too... cuz my pics are usually good! hahaha.
Hope all is well!
PS> Yeah, on the springs.... I just have other things I wanna do first, ..but some day! I know "Long Beach Spring" is one of the best... but WOW, really spensiveness! lol. Whatever I do will be 'pull and replace'... modifying the body/frame mounts, etc. I LOVE the sound of the 63's.... but there are others that are bolt in that are really nice for a 2" lift or so, right? OME maybe? lol. I just don't want "SUperlift" or "Rancho" springs, I guess... heard those all go flat faster than the stock ones did! lol.
At least for now, I'm SUPER happy with what these Zuks have taken me through! Some day though... sure nuff, I hear ya!
