1995 Toyota pickup 2WD rear lift
Old Apr 11, 2024 | 05:25 PM
madmax872's Avatar
I have a 1995 Toyota pickup DLX (two wheel drive). I will install 4crawlers Ball Joint Spacer and Upper Control Arm Braces in the front. It will make a lift approximately 1.5 inches. I am not sure what's the best way to lift in the rear. I see several options: 1) shackles 2) block with longer U-shaped bolts and 3) add-a-leaf.
Which option should I go with? and why?
THANKS
Old Apr 11, 2024 | 06:47 PM
ryanthegreat1's Avatar
Doesn't the axle sit above the rear springs? Making blocks a lowering option not a lift option.
Old Apr 11, 2024 | 09:13 PM
Robert m's Avatar
Yes blocks will lower it
Do the shackles and if you need more lift, look at add a leafs.
CPELEGRIN
Feb 10, 2017 10:55 PM
adams707
Feb 7, 2016 07:50 PM
Diesel_Panda
Mar 5, 2014 11:32 PM
Rebel5
Sep 23, 2007 01:04 PM
alanbobalan
Feb 3, 2007 03:34 PM
