1994 Toyota pickup automatic transmission fluid type
Old Feb 10, 2016 | 11:34 PM
alva22re's Avatar
i have a 94 toyota pickup 2wd automatic and i want to do a transmission fluid change but i dont know which type of fluid is it?Does anyone on here know.
Old Feb 11, 2016 | 12:44 PM
MudHippy's Avatar
Dexron III.
Old Feb 15, 2016 | 10:30 PM
alva22re's Avatar
ok thanks
Old Feb 18, 2016 | 07:32 AM
coffey50's Avatar
An ASE Master Cert friend of mine who loves toyota *owns a first gen t4r*
Recently told me to use Castrol Transmax Import, for what its worth.
Old Feb 18, 2016 | 08:21 AM
MudHippy's Avatar
You can use whatever you want, technically. But it will make a difference what you use. If you want it to perform how it did from the factory, you should use Dexron III or Toyota T-III. That's what it's designed to use. Personally I highly suspect any All-In-One type fluids. Since OEMs don't use or recommend them.
It's funny your ASE buddy didn't mention these things, or why you should use what. Shows what he knows I guess.
Old Feb 18, 2016 | 09:44 AM
Janos01's Avatar
Also be aware that if your truck has not had regular service on the transmission, you might create a problem vs preventing one. For example, a transmission with 120K miles that has not had regular service, could either die, have issues or be ok. Basic rule, if you have high miles on a transmission and it is still working ok, do not mess with it.
Old Feb 18, 2016 | 10:39 AM
coffey50's Avatar
It was designed to be used with Dexron III ?
My FSM says Dexron II, I don't know if its a legit Toyota FSM though.
So I asked him what I would use because you won't find Dexron II anywhere. So he responded with my aforementioned fluid.
Old Feb 18, 2016 | 06:29 PM
hockey88fan's Avatar
Yeah thought it was II. But II was replaced with III I believe. And there's dexron/mercon that says it's a suitable replacement for III. Doing a fluid change myself, concerned that when I drain the fluids that of course it won't be completely drained, so does the new stuff mix with the old stuff well?? Who knows I'm confused.
Old Feb 19, 2016 | 09:16 AM
rustypigeon's Avatar
The original fluid was Dexron II, which was later superceded by Dexron III. Manufacturing licenses to produce Dexron III expired about 10 years ago. Companies are still manufacturing Dexron III type fluids, however they are not allowed to call them Dexron III since they don't have a license. You will often find these fluids called "Dex/Merc".
I have used Castrol Transmax Dex/Merc for the past several years in my older vehicles that call for a Dex II or Dex III fluid. It meets the specifications and is easy to find.
http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/ACA4A5252B86FEC580257AA9005367AF/$File/Castrol%5FTransmax%5FDEX%5FMERC%5F03520.pdf
The msds shows it to be a Dex II/III fluid.
Old Feb 19, 2016 | 02:07 PM
Originally Posted by rustypigeon
The original fluid was Dexron II, which was later superceded by Dexron III. Manufacturing licenses to produce Dexron III expired about 10 years ago. Companies are still manufacturing Dexron III type fluids, however they are not allowed to call them Dexron III since they don't have a license. You will often find these fluids called "Dex/Merc". I have used Castrol Transmax Dex/Merc for the past several years in my older vehicles that call for a Dex II or Dex III fluid. It meets the specifications and is easy to find. http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/ACA4A5252B86FEC580257AA9005367AF/$File/Castrol%5FTransmax%5FDEX%5FMERC%5F03520.pdf The msds shows it to be a Dex II/III fluid.
Good info, thanks for clearing some things up.
Old Feb 20, 2016 | 01:39 PM
Working on it now. FSM says to use fipg gasket maker, I have that but I also have a cork gasket that came with the trans filter. Using the fipg seems like it will be tricky to get the pan back together with the driveshaft partially in the way and also laying on my back trying to line everything up. Cork gasket seems like a much easier install, not sure how it will hold up. I'm torn, any advice?
Old Feb 20, 2016 | 04:21 PM
I've always used a gasket, never had any leaks. I prefer the gasket because it saves me from having to scrape all the FIPG off the mating surfaces the next time I remove the pan.
Damiandominguez
Jan 28, 2016 01:58 AM
4runner3.0
Jan 27, 2016 07:36 AM
Chris Parker
Jan 21, 2016 06:11 PM
jordanhere123
Jan 12, 2016 12:23 PM
