1994 sr5 3.slo fuel tank wiring ...
Old May 28, 2019 | 11:56 AM
ShopTeacher's Avatar
Hello all, i have removed my fuel tank - 9 years ago - and cannot for love money or google recall where the fuel tank wiring harness plugs into the vehicle... it has a rectangle 10 pin plug that has a sealing grommet *(passes through the body somewhere)
Old May 28, 2019 | 01:43 PM
scope103's Avatar
Welcome back!
The fuel pump goes to connector F6, and the sender to F7. I can't determine the exact number of pins, but it looks like F6 might be two pins, and F7 3 or 4.
F6 and F7 are part of the "Frame Wire." The Frame Wire connects to the "Cowl Wire" through BG1, which is under the passenger seat.
Note that BG1 (in my '94 EWD) has 14 pins, not 10, so your experience may vary.
And there's just no reason to rush this repair ....
Old May 28, 2019 | 02:11 PM
Thanks for the reply, just saw my other posts... yup been away awhile ... also, i forgot to mention this is a 4runner... however, the fuel tank i am using to make this dog run is from my 86 1ton 22r with an injected head.... guess i like things complicated... ill have a look under my pass front seat and see what i can find... again, many thanks for the assist!!
Gadgedizzle
Oct 8, 2015 12:40 AM
Mikronized
50
May 11, 2015 04:43 AM
Blk63vette
Apr 5, 2011 08:13 PM
TerrCat
Nov 5, 2010 11:48 AM
