1993 SR5 timing problems?
Old May 31, 2011 | 02:34 PM
tdort's Avatar
Hi all ,I am a newbie here , any help would be appreciated. the 93 pickup started running rough and stallin.idling in the driveway I noticed rattling from the distributor,when you put your hand on the distributor ,you can feel the rattle. is this gear driven? I tried to set TDC with a wrench on the balancer,when the marks line up,the rotor points to plug # 5 (or 4o'clock position),360 % later,it points to about 10 o'clock,and I cant get it to point to #1 plug.Is this an indication of a worn distributor shaft?I cant do any thing with timing untill I'm sure #1 is at TDC.thanks
Old May 31, 2011 | 02:40 PM
4Crawler's Avatar
What sort of engine? Guessing a V6 from your description.
Old May 31, 2011 | 02:57 PM
tdort's Avatar
yes it's a v-6
Old May 31, 2011 | 07:06 PM
scope103's Avatar
Save yourself a lot of work; get a timing light. http://www.harborfreight.com/xenon-t...ight-3343.html
The distributor is gear driven, but you did NOT all-of-a-sudden jump a tooth. (If you had, it would be off by about 27 degrees, and would be unlikely to run at all). Hook up the timing light following the manual, and see where you are.
You suspect loose parts in the distributor. What you'll be looking for, then, is the timing mark jumping around, as it fires with different advance each time around.
Good luck!
Old Jun 1, 2011 | 02:01 PM
tdort's Avatar
thanks Scope.I have looked at the timing with a gun,and cant get the marks to lign up at all(advancing and retarding distrib.wont line up either).Manual says !0 degrees before TDC.another thing,about two weeks ago ,the boy was out driving it,and he called for me to bring tools as the power steering mounting bolts had worked loose,throwing the belts.Could this have maybe caused the timing belt to jump,if there was some resistance as the other belts jumped and jammed??? IDK. thanks all for your input.
Old Jun 1, 2011 | 02:05 PM
tdort's Avatar
By the way this is the boy's truck n he don't tell me anything untill its to late.Another wkend under the hood!!!!!
Weidle
Jan 21, 2019 05:39 AM
Colington
Oct 12, 2015 05:41 PM
Valvoman
Jun 28, 2015 02:45 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
marcusSRG
Jun 27, 2015 07:13 AM
