1992 Toyota Pickup Tick Noise
Old Oct 29, 2013 | 12:25 PM
Hunt Gath's Avatar
Curious if anyone can help diagnose the ticking noise in my Yota. Check out my youtube video I uploaded. The smog pump is kinda loud. Also, does it sound like my timing chain is slapping the cover when I give it gas?
Thanks,
Hunter
Old Oct 29, 2013 | 12:28 PM
Hunt Gath's Avatar
Well apparently my vid upload didn't work, i'll get it.
Old Oct 29, 2013 | 12:30 PM
Hunt Gath's Avatar
Round 2
Old Oct 29, 2013 | 12:33 PM
HighLux's Avatar
adjust your valves
Old Oct 29, 2013 | 12:44 PM
Hunt Gath's Avatar
What about the chain, does it sound like it's hitting the cover?
Old Oct 29, 2013 | 02:08 PM
cheez's Avatar
IT kinda does, but you wont know until you remove the valve cover, start with a valve adjustment and inspection of the t-chain guide while you are in there.
Old Oct 29, 2013 | 04:26 PM
Hunt Gath's Avatar
Pulled the valve cover, drivers side chain guide is gone, chain has barely touched the chain cover though. Guess she will have to sit until I can get the timing chain replaced.
Old Oct 29, 2013 | 04:28 PM
HighLux's Avatar
A guy could make a living doing timing chains in Colorado it seems.
Old Oct 29, 2013 | 04:32 PM
Hunt Gath's Avatar
should I go with OEM parts? Or less expensive?
Old Oct 29, 2013 | 04:43 PM
HighLux's Avatar
engnbldr.com call them talk to Ted.
order:
you want
waterpump
oil pump
timing set with steel rail on driver side
upper gasket set
you said timing cover was good?
Should be like $100 some odd bucks? Been several months since I did mine.
Toyota head gasket. Manditory.
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
zytra
Jun 24, 2015 08:14 AM
