1992 Toyota 4wd extra cab 22RE
Old Nov 29, 2014 | 07:16 AM
Fatlipnatties's Avatar
Gents , i have changed the tank&fuel pump due to rust from sitting up for years. Truck ran great for 30 plus miles i was down shifting to a complete stop at a stop sign with clutch in motor stalled lights came on dash cluster , spun over but would not crank , pushed to side of road 5 minutes later cranked an ran great for 4 miles until i down shifted killed again . Got a push back home the next day cranked right up , heated up to operational temp, test drove a mile killed engine back in the drive way it will bot crank now On passenger side ECM i think is clicking like a relay after spinning motor over. I have 12volts at +B on diognostic in engine compartment, when i jump FP to +B I have nothing as far as fuel pump running. Gents i would greatly appreciate any advice!
Old Nov 29, 2014 | 07:53 AM
wyoming9's Avatar
Red face
Well I can only guess Just what fuel pump??
Poor connection at the fuel pump connection ??
Cheap one size fits all pump quit??
Jumping out the B+ to FP bypasses all the safeties .
It has to be in a super quiet garage to hear the fuel pump run if the filter is now blocked it will only burn out trying to push through the blockage.
No mention of changing filter was that just an over site??
All the rust in the lines is now in the filter.
You have a failure to start issue.
Failure to crank means it does nothing(does not turn over) different people use different terms.
Old Nov 29, 2014 | 08:07 AM
Failure to start
Poior connection at the fuel pump connection ??
i did change fuel filter & sprayed cleaner in delivery line from the back broke line loose at the front an blew the line out good with air compressor i put a Bosch pump in!
Old Nov 29, 2014 | 03:44 PM
Pump issue
Thanks Wyoming9 , I performed a simulated test with old fuel pump. Its definitely the fuel pump. Do you recommend any other brand of pump other than Denso, or?
Old Nov 29, 2014 | 11:56 PM
jennygirl's Avatar
I just got a new denso FP from sparkplugs.com
$110 for the base and $120 for the kit which includes a few goodies like the pre pump filter catch thing.
Pretty darn good deal for an OEM fuel pump. I suggest you go with the denso! Makes the car start up on a dime!
Old Dec 1, 2014 | 12:13 AM
anndel's Avatar
Ditto on the Denso. I got mine from rockauto 5 years ago and Denso makes the OEM fuel pump as the case on the old FP was stamped "DENSO".
zd92655
Mar 6, 2022 12:58 PM
puffin04
Jul 10, 2015 09:17 PM
Gamble_STi
Jul 1, 2015 12:51 PM
Eagle564
Jun 23, 2015 11:29 PM
94more
Jun 19, 2015 01:55 PM
