1992 4x4 4runner Real Main Seal
Old May 21, 2014 | 09:14 PM
92-4runner4x4's Avatar
Hey, Guys! I Need some Advice on How to change my rear main Seal? is it gonna take alot of work of changing the Seal? Please I need Advice! Thanks!
Old May 21, 2014 | 09:58 PM
YotaWoRx's Avatar
You will need to remove the transmission to gain access to the seal.
Old May 21, 2014 | 10:01 PM
yeah I know! I'm planning in ripping the tranny out tomorrow! Once I do get it out is it hard to change ?
Old May 22, 2014 | 05:55 AM
Smaay's Avatar
changing the seal is not hard. remove the trans, then remove the clutch and flywheel if MT or the flex plate if auto. the RMS is right there around the crankshaft. I have a hooked shaped tool that i just stab into the seal, get a grip and pull it out.
Once its out, clean the area, apply a light coating of grease around the new seal and tap it in evenly
Old May 22, 2014 | 06:31 AM
scope103's Avatar
Page 115 http://personal.utulsa.edu/~nathan-b...ne/69cylin.pdf
According to the manual, you can replace the seal with or without removing the seal retainer.
Alaskan91
Sep 21, 2015 04:39 AM
Jmiller1023
23
Aug 6, 2015 07:03 PM
toyota32
Jul 6, 2015 05:42 PM
CJ94yota
Jul 3, 2015 10:14 PM
