1991 V6 water outlet bolts.....help!
Old Oct 8, 2008 | 06:31 PM
Scottg97's Avatar
Thumbs down 1991 V6 water outlet bolts.....help!
I have a 1991 SR5 V6 3.0 4x4 Pick up extra cab.
I was replacing the water outlet and I broke one of the bolts on it. What is
going to be my best route to fix this. I noticed the the bolt has a "hex" type
head on it. Can it be un-screwed and replaced? Or I'm I going to have to
drill it and tap it?
Thanks
Old Oct 8, 2008 | 06:35 PM
fillsrunner4's Avatar
post a pic so we can see what your dealing with. You could probably jam nut it maybe or drill it out and im sure you can get a new one (dealer)
BTW welcome to YT
Old Oct 8, 2008 | 06:45 PM
jason191918's Avatar
X2 on pics. Are you talking about the 2 studs?
Old Oct 8, 2008 | 06:52 PM
Scottg97's Avatar
Yes, one of the studs snapped.
Old Oct 8, 2008 | 06:59 PM
Try an EZ out.
Maybe try some heat.
Drill and tap it.
I forget how much room there is around there. If there is enough room, drill and tap will probably be the easiest.
Old Oct 9, 2008 | 08:00 AM
annoyingrob's Avatar
My buddy had this same problem on his 5M.
He put a little C-clamp on it. Looked hilarious.
Old Oct 9, 2008 | 08:15 AM
Blurr's Avatar
the studs can be removed so try an easy out. you can get replacement studs at your local dealership.
Old Oct 9, 2008 | 11:04 AM
Noltz's Avatar
Did it snap flush? The hex head on it is actually an inverted torx used during assembly. Yes, they can be removed. They're held in with a bit of sealant. If you can still grip it, then Vice-Grips clamped as hard as you can has always worked for me. Work the stud back-and-forth to break up the sealant.
Old Oct 9, 2008 | 11:06 AM
Or drill and tap it and just use a bolt.
SubiKing
Aug 21, 2021 03:57 AM
andrewflores17
Nov 25, 2010 02:54 PM
motobro
May 1, 2009 02:55 PM
Scottg97
Oct 8, 2008 06:49 PM
