1991 4 runner v6 manual trans 3.0
Old Nov 29, 2014 | 03:40 PM
chelshark's Avatar
I replaced power steering pump now unit below I dont Know what it is is leaking from top power steering filud all over ,does any one know what it is ?1991 4 runner v6 manual trans 3.0-20141129_155818.jpg
Old Nov 29, 2014 | 04:10 PM
scope103's Avatar
The unit in your pictures is the ABS actuator. http://personal.utulsa.edu/~nathan-b...13generald.pdf
But you can't possibly tell if it is leaking in the state in which you photographed it. Fluid is all over the place -- even on the battery tray!
Clean it up first; for this, soap and water (garden hose) will work fine. Then start it, run it for 15 seconds, stop and look carefully for leaks.
Gravity is not your friend; if anything above the actuator leaks (PS pump, hoses, etc.) it will soak the actuator.
Old Nov 29, 2014 | 08:30 PM
chelshark's Avatar
help auctour
Thank U so much u r awesome. I will clean it up and post more progress.
Old Dec 8, 2014 | 05:37 PM
chelshark's Avatar
1991 Toyota 4 Runner SR5 4 wheel drive
I finally got the break accuatior off here are pics
Attached Thumbnails 1991 4 runner v6 manual trans 3.0-20141208_180456.jpg   1991 4 runner v6 manual trans 3.0-20141208_180741.jpg   1991 4 runner v6 manual trans 3.0-20141208_181050.jpg
Old Dec 8, 2014 | 05:41 PM
chelshark's Avatar
now I just need to find out what kind of gasket I need to use
TheBFA
Feb 15, 2020 06:55 AM
SpookyMulder
Nov 4, 2015 11:56 AM
voiddweller
Oct 2, 2015 07:47 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
