I need a new throttle cable is this a dealer only item? Also anyone have place to either get power door. Door panels? Or maybe the cad drawing of them? Thanks!
Toyota dealers do not carry the throttle cable for older cars as they have to get it after market. They can still get it for you and You should be able to get it at any auto parts store. If you need the cable replaced, I would recommended taking it to the dealer or a shop that only specializes in Toyotas as the cable runs from the throttle body into the transmission.
Regarding the door panels, the Junk yard, Rock Auto or ebay should have them.
http://www.toyotapartsoverstock.com/...tring=throttle About $85. Want to find it after-market? Do what RJR does; just google the part number. If you do that for this part, you'll find Amazon has it ... for about $2 more. Other than that, I've never seen them.
Originally Posted by Janos01
.. as the cable runs from the throttle body into the transmission.
I assume you want the "throttle cable," that runs from the gas pedal to the throttle. There is another cable for the cruise control, and a third cable for the throttle link to the automatic transmission (sometimes called a "kick-down" cable, but that name has nothing to do with its function.)
RockAuto does carry a number of door components (like regulator and motors), but they don't have the interior door panel. A junk yard might work, but keep in mind that there are quite a few variations. Take a picture with you.
