1990 Pickup DLX to SR5 Frame up body swap (pics included)
Old Nov 14, 2009 | 05:35 AM
HAI-TEK7's Avatar
Talking 1990 Pickup DLX to SR5 Frame up body swap (pics included)
Hey everyone,
I got a 90 P/U has some rust on the rear coners of the cab, was going to cut and weld it, but came across a good deal on some new sheet metal.
This is my DD, it will only see light trail blazing from now on.
Anyway here are some pics of progress. My goal is to have it back on the road by Thanksgiving.
As she sits. I did some body work on the bed and bottom of the doors.
Started the strip down
Got the bed off, and started grinding,sanding,prepping the rear of the frame awhile. I just used Rustoleum gloss black.
THE PARTS CAME YESTURDAY!!!!!!!!!!!!!!!!!! The new parts are off a 1990 SR5 V6, 5 sp. So now I've upgraded to tilt steering, clock, 60/40 bench, intermitten wipers ect. Also most of the AC components are there too, i will definitely try to get that back in order. This was the ONLY thing I wish my truck had.
Needs to be cleaned. Only flaws so far is the dash is cracked, and the roofs clearcoat is gone.
Old Nov 14, 2009 | 05:49 AM
xxxtreme22r's Avatar
any plans on getting rid of that radiator? or the old one? my fins are in bad shape lol. anyway, what a shame on that clunker deal, hopefully that was a 3.slow and not a 3.4 they clunked.
Old Nov 14, 2009 | 07:55 AM
HAI-TEK7's Avatar
Yeah, im going to get rid of everything i swap out. It was a 3.0.
Old Nov 14, 2009 | 08:13 AM
yotaman90's Avatar
I've never seen the red interior on the 89-95 trucks, it looks good!
Old Nov 14, 2009 | 08:37 AM
camo31_10.50's Avatar
pretty sure it couldnt have been a 3.4....3.4 didnt come along until '95.5
of course it coulda been swapped ...HIGHLY doubtful though..
and i've never seen a 60/40 split bench....i'd love to have that in my '86 ext cab LOL..i dont like buckets much anymore....can't have a girlfriend ridin in the middle on the center console..lmao
Old Nov 14, 2009 | 12:56 PM
HAI-TEK7's Avatar
Some progress
Not too much today, weather was pretty crappy up here. Cleaned the engine bay and vacuumed the interior.
Hopefully tommorrow ill get my cab off my frame.
Yeah its not to shabby. Since the dash is cracked, im going to switch mine into it, but im going to paint mine black. I think alittle contrast would be good.
Yeah, im pretty stoked abput the 60/40. i have buckets that i was going to use, but i like the bench b/c I got a 85lb dog thats ass is too big for a bucket.
Old Nov 15, 2009 | 01:40 PM
HAI-TEK7's Avatar
more progress......
Got some more done today. Since the new cab is a v6 i found some differences. The fuse box to fuse panel (kick panel) harness is different. So i had to swap that out. Luckily the passenger side harness unplugged from the fuse block, so i didnt have to swap the dash harness also. That would have sucked.
Here the 2 harnesses side by side. 22re on left, 3.0 on right. The battery cables were cut on the v6 harness.
22re on bottom
Heres the 2 black plugs that i un plugged from the block. Hopefully the rest of the dash harness is the same.
Does anybody know what these 2 plugs are for? i know that go to 2 vacuum solenoids, but what are they for? Any help will be appreciated. These 2 plugs are the only differences i seen so far. There are located right by the fuse block passenger side.
Here my engine with all teh accessories bundled up, ready for cab to be lifted.
I still have brake lines and fuel lines to disconnect, the we can have lift off.
Old Nov 15, 2009 | 01:59 PM
MaK92-4RnR's Avatar
Holy Red interior batman... I'm even more thankful for my gray interior than I was before... :O
Old Nov 15, 2009 | 02:03 PM
cgeorge's Avatar
that is total badass... great pics!
Old Nov 21, 2009 | 09:23 AM
HAI-TEK7's Avatar
Talking How to remove a cab by yourself.
I got the cab off by myself this morning. It was quite an adventure.
My pick point was the bracket that is welded on the body below the radio/climate control. As you can see it wasnt at its centroid. It was dam close, because i could just pick the back up and move it.
I would recommend removing the radio support thing that goes from the bottom to the top, i fudged it up. Also you might want to remove the heater core box, i cracked that too(that white thing).
I guess when i put the other cab on, i need to go another route. All in all it went good for a one man job. If you had one other persson, it would have been cake.
No time to clean and prep the frame for some paint.
Old Nov 21, 2009 | 10:32 AM
pwd's Avatar
pwd
Holy cow. Good job, get a second person when installing the cab; wouldn't want to damage anything. Be sure and take some more pics too. Good luck.
Old Nov 21, 2009 | 11:15 AM
Teuf's Avatar
Quite an endevor, way to go.
Old Nov 21, 2009 | 11:31 AM
cgeorge's Avatar
wow.. that is awesome!
Old Nov 21, 2009 | 11:32 AM
Ezrider_92356's Avatar
good work so far, and good idea on using the engine hoist to lift the cab i never thought of that before. i have always just rounded up a bunch of people when iv had to take a cab on or off witch sometimes means a few day delay in your project. also how is that working out with the whole clunker title thing?
Old Nov 21, 2009 | 11:54 AM
HAI-TEK7's Avatar
Thanks for the comments. I def will have another person to put the cab on.
To do it by the book, i will use my vin/title and apply for new vin tags. New vin tag will match my current vin, then i guess i have to go somewhere to rivet them on.
Old Nov 21, 2009 | 12:07 PM
mic's Avatar
mic
cool project
are you keeping the wire harness?
Old Nov 21, 2009 | 12:21 PM
HAI-TEK7's Avatar
Originally Posted by mic
cool project
Which harness? If your talking about the 3vze, no im not. Its listed in my forsale thread.
Old Nov 21, 2009 | 01:03 PM
iamsuperbleeder's Avatar
were it me, this would take me an extra day, because I'd waste a day just trying to get it drivable as a rolling chassis, and then just drive down the street, maybe to the store or something, lmao
great progress man!
Old Nov 21, 2009 | 01:14 PM
mic's Avatar
mic
yes i need the 3vze harnesses
Old Nov 21, 2009 | 01:56 PM
HAI-TEK7's Avatar
I got it with ecu for $50 plus shipping. PM me if you want it. It doesnt look like any of the plugs are cut, I'll take a closer looke tomorrow.
