1989 4Runner clutch pedal noise?
Old Jun 20, 2022 | 06:39 PM
brdyer92's Avatar
My 4Runner’s clutch pedal makes a strange clicking noise when I’m pressing and depressing it, like a clicking/popping noise that I can almost feel with my foot if I press it down slowly enough. It doesn’t seem to be anything in the transmission, it sounds like it’s coming from the inside of the car. I sprayed the moving bits around the pedal and the bushing with silicone spray and that didn’t do anything. Coworker of mine determined it’s likely the master cylinder, though I don’t currently have any other symptoms relating to that and would like to further troubleshoot before I go replacing parts.
Any tips or advice would definitely be appreciated!
Old Jun 20, 2022 | 07:26 PM
aztoyman's Avatar
The bracket is known to crack. Take a close look as it may be the source of your noise.
Old Jun 21, 2022 | 02:58 AM
JJ'89's Avatar
Yes. Mine failed from metal fatigue at 163,000. Search on this site for posts on DIY repair. Need welding eqpt and skills. I had mine done at a shop, new bracket, along with the shifter bushing and seat replacement.. $463 14 years ago. I think I read somewhere that not having your foot squarely on the pedal when you push it in can hasten the failure.
Old Jun 22, 2022 | 02:21 PM
Jimkola's Avatar
YT Community Team
5 Year Member
I dunno about foot placement. We started replacing them fairly early on. Didn’t seem as robust as they maybe should have been.
Old Jun 23, 2022 | 11:15 AM
COMTB's Avatar
Mine actually wore out the hole where the master mounts to the pedal and made a creaking sound. Was able to buy a new pedal and replaced all the bushings/regreased the spring while I had it all out. So there's a few issues it could be.
Short list:
Worn spring bushings
Cracks somewhere in the linkage/pedal
Worn hole (ha) where the master mounts to the pedal
Old Jun 23, 2022 | 05:32 PM
Blueman's Avatar
Check to see if it's the proximity switch making the noise, or the interface with it.
harris32
Jun 19, 2014 09:23 PM
mldave
Oct 15, 2012 04:07 AM
path
Mar 1, 2008 09:40 PM
SuaveGato
Aug 30, 2006 03:16 PM
Bob_98SR5
26
Jan 20, 2006 05:15 AM
