1989 4runner 4" Trail Gear Sas and 63s....advice for leveling
Old Aug 3, 2018 | 03:06 PM
4runner4us's Avatar
Gents.....as the title says....1989 First Gen 4runner, recently installed a 4" TG SAS kit. The truck has Chevy 63's with 2" blocks, that was pretty level with a 4" bracket IFS front end. Now the truck is pretty tall in the front...the back is sitting relatively low, I'm guessing its 2-3 inches higher in the front. Since I already have the 63s in the back with 2" blocks, I am thinking about some Chevy 63 lift springs (Procomp offers 3.5 and 5.5 inch lift springs / Tough Country offers 5.5 inch). Maybe going 5.5 lets me eliminate the blocks altogether.. Does anyone have any experience with either of these? Or have any other advice for getting the truck level?
Old Aug 5, 2018 | 07:49 AM
4runner4us's Avatar
Pics...cuz we all like pics.
Old Aug 5, 2018 | 11:17 AM
dropzone's Avatar
Fossilized
that is part of the problem of the design of the T-G front hanger, it basically adds 1.5-2" of lift to a 4" lift
it looks like your front hanger was mounted pretty far forward based on your shackle angle
when was the SAS done?
Your springs will settle somewhat over the next month or so. I would give it a few weeks before you start messing with the rear springs to bring it up...
Old Aug 5, 2018 | 11:28 AM
Discombobulated's Avatar
No advice here but it looks killer!!!
Old Aug 6, 2018 | 10:16 AM
YOUNGIAM's Avatar
Go bounce it around, the springs will settle.
Old Aug 6, 2018 | 10:29 AM
4runner4us's Avatar
Thanks for the comments....the SAS has only been done for about a week and I've only driven it about 100 miles and took it out to flex and play around once (front-end flex is incredible).....I'll go drive it in the rocks and on the trail a little more and see if the springs settle an inch or two as most say. Even if it settles and inch or two, the front will still be a little higher than the rear...so I guess I can level it then...
Old Aug 6, 2018 | 11:29 AM
se7enine's Avatar
That seems pretty low in the back for chevy's. How many leafs is it? Maybe you can upgrade to a heavier spring and bigger shackle. It looks as low as mine does with OME Mediums.
Old Aug 14, 2018 | 03:40 PM
4runner4us's Avatar
4 leafs..I removed the overload leaf. The overload looks to be about an inch thick, it would probably add some arch to the leafpack and net me a little more than an inch of lift.
SpecialScottie
Oct 14, 2017 04:01 AM
skunkwhat
Apr 12, 2016 02:57 PM
dbbowen
Apr 6, 2016 06:00 AM
yogmuney
Oct 21, 2009 08:36 PM
red87
Nov 5, 2008 01:35 PM
