1989 22r no spark igniter wiring
Old May 19, 2024 | 01:50 PM
trialrunner21's Avatar
Question 1989 22r no spark igniter wiring
guys - my 1989 22r is not starting. when checking the voltage to the igniter (gray connector with 2 wires (top and bottom relative to connector release), i have voltage on the top wire, but 0 volts on the bottom. can someone verify if this is correct - or should both wires carry voltage ? i need my truck so any help much appreciated. if someone has a similar 22r and a voltmeter this issue could be resolved quickly, turn ignition on, open connector (pull release up), ground voltmeter on bolt holding igniter, probe both slots in the female connector, note voltage if any, about 3 mins or so.
Old May 20, 2024 | 03:38 AM
NorthAveRacing's Avatar
Did you find your issue? I just picked up an '89 and it has no spark. I'm thinking igniter as well. It appears someone has replaced everything else.
Not sure If I'm on correct wires as OP...My (2) wires in the black plug one has 4.9 volts the other has 10 volts
Old May 20, 2024 | 06:53 AM
Jimkola's Avatar
YT Community Team
5 Year Member
What color are your wires? If the wire has a stripe, include the color.
Old May 20, 2024 | 10:25 PM
sorry to take so long to reply. have you made any progress on your starting problem ?
Old Jun 4, 2024 | 12:55 PM
problem identified and fixed with a jury rig
I purchased a 12 volt to 5 volt converted from amazon and used it to replace the 5 volt signal from the (I believe) ECM. Truck started first try. Thanks to NorthAveRacing and Yota for your assistance. The 4.9 volt found by NorthAveRacing was very helpful.
PremiumOctane
Apr 20, 2021 08:30 PM
Yougnay Samatha
Feb 17, 2020 04:03 AM
rcrumpley
Mar 23, 2016 11:16 AM
ericdg16
11
Jan 19, 2010 09:06 AM
the_supernerd
Jun 28, 2006 11:44 PM
