General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
12 volts at igniter
Old Mar 22, 2016 | 03:42 PM
rcrumpley's Avatar
12 volts at igniter
My son purchased a 1987 Toyota pickup basketcase - really had a head gasket problem but was taken apart.
We have the head fixed and back on but I cannot find 12 volts at the igniter.
I have 12 volts at the ignition switch, but not at the IGN fuse on the fuse panel at the drivers feet.
I wanted to find where the 12volts should be at the igniter and see if I can supply 12 volts to see if we get spark.
There is a 2 wire connector that appears to be the proper place after looking at the wiring diagrams. In the picture below the green connector that is not capped is where I believe the hot wire should be.
1987 Toyota pickup igniter and wires
Is that the right place for the hot wire? Does anyone know which one is hot? Do you know what the other one is?
Thanks for any help!
Rob C
Old Mar 22, 2016 | 11:40 PM
wyoming9's Avatar
Red face
Is this a 22R ??
Is this the original engine ?? Only because in 87 they have gone to the check connector.
The Igniter coil looks like from a older engine.
Maybe that is why the wiring diagrams make no sense.
Old Mar 23, 2016 | 05:04 AM
rcrumpley's Avatar
Yes it s a 22R (and from an earlier year or modified with the dual width timing chain). But from what I have seen a 22R was available in 87. It is possible a past owner changed the wiring harness as well.
Rob C
Old Mar 23, 2016 | 11:16 AM
wyoming9's Avatar
Red face
Toyota is real good for changing Plugs and wire colors between years
Looks like you have a 85 or older engine in there .
Which makes trouble shooting electrical issues quite Frustrating
Then do you have Federal or California Emissions That makes a difference
California Emission Vehicles are all over the country .
Till you know just what year EWD to look at.
if it has the 1987 Harness the 12 VDC supply should be Black /red stripe
mtnkid85
3.4 Swaps
13
Jan 26, 2026 04:58 AM
Bajawfo
11
Mar 30, 2016 04:49 AM
toypower
Mar 22, 2016 06:32 AM
gillesdetrail
Mar 17, 2016 05:09 PM
Vernsyota
Mar 7, 2016 04:41 PM
