1987 fsm
Old Apr 15, 2017 | 05:47 AM
TrafficTechII's Avatar
1987 fsm
Been looking for the 87 fsm without any luck. I did run across and download one for the 1988 truck/4runner and found several other online here.
http://manuals.co/workshop/toyota/4-runner
My question is the 88 fsm the same as the 87 fsm or did they make a lot changes between the two years?
thanks
Old Apr 15, 2017 | 07:22 AM
wyoming9's Avatar
Red face
Just enough changes to make things interesting
Mostly in the Electrical end.
Brakes Suspension Mechanical things are pretty much the same.
Old Apr 15, 2017 | 03:35 PM
Terrys87's Avatar
87 and 88 injectors are different. The O2 sensor is in the Exhaust Manifold on an 87. 88 trucks have in the exhaust pipe. 88 as a few more emissions on it then an 87. Most things other wise the 87 manual will work.
Old Apr 16, 2017 | 11:47 AM
Thanks Gents.
I will keep hunting for the 87fsm.
Old Apr 16, 2017 | 03:43 PM
flg8r22's Avatar
Central Florida Toyota will get them. Last one I bought was for an 81. I think it was 70 bucks or so. Also Lakeland Toyota does alot of online sales and may sell the cheaper if your actually looking for a hard copy
Old Apr 17, 2017 | 10:24 AM
If anyone needs the 88 truck/4runner fsm see the link below. Its about 1400 pages.
http://rapidgator.net/file/afe0c08ca...er_88.pdf.html
Old Apr 19, 2017 | 08:19 AM
RAD4Runner's Avatar
Yes, there are a few changes.
I have a print 1986 FSM and found that on 1988 22R-E ECU also takes part in grounding STJ. (Note the additional wiring between STJ of CSI timer and STJ of ECU below. Quite possibly same as in later engines)
I do not now about the 1987. TrafficTechII and others who have 1987's , when you get a chance, pls check is you have a wire connected to STJ pin of your ECU and let us know what color.
Old Apr 19, 2017 | 01:18 PM
dropzone's Avatar
Fossilized
1987 service manual on eBay
Look at this on eBay http://www.ebay.com/itm/322484654169
I had the hard copy for my 81. Actually sold it for more than I paid for it after greasing it up for 10 years
Old Apr 19, 2017 | 02:14 PM
Rad4runner,
Mine is the 22R carb.
Did they use the same terminal block from the 22R/Carb to the 22R-E?
I will check and see what I have..
Dropzone,
Thanks for the heads up. I called CFT like flg8r22 said, they are looking for one. Thats what they told me 2 days ago...
