1987 4runner rear window switch
Old Oct 4, 2021 | 06:56 PM
ugly_runner's Avatar
My rear window rolls up and down with the key switch but not the center console switch. I opened and cleaned the center console switch and it still doesn't work. I jumped it at the center console switch plug and it works up and down. Does that mean its a bad switch?
Old Oct 4, 2021 | 11:47 PM
RAD4Runner's Avatar
Originally Posted by ugly_runner
... I jumped it at the center console switch plug and it works up and down. ...
You mean you unplugged the center console switch from the connector on the harness, and you jumped pin 1 to pin 2, then pin 5 to pin 2?
If so, yes, in the past 34 years someone must have poured coffee, soda, beer, etc on that switch at least once
How First-Gen MoreFunner Rear Window Control Works : https://www.yotatech.com/forums/f199...l#post52234507
Old Oct 7, 2021 | 07:10 PM
Yes exactly so i had it narrowed down to a bad switch. I opened and cleaned it once and it did not work. So i was suggested to bend the see saw part inside a bit so it applies more pressure to the contact points and it works now. So if you feel your switch is bad clean and bend the see saw part inside a bit before re installing the switch. thanks!
Old Oct 9, 2021 | 07:20 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Sounds like a bad switch, but you might want to clean the window lock switch, too, and see if that has any involvement.
stav
Jul 7, 2015 07:57 PM
CRafferty
Jul 18, 2009 06:18 AM
woodworth
Jun 8, 2006 08:06 AM
Worley
Apr 4, 2006 09:15 AM
