1987 22r wont crank
Old Nov 6, 2011 | 07:16 AM
rfs002's Avatar
1987 22r wont crank
Can't seem to figure out what is going on with my 87 22r maybe someone can help me. it starts up fine when the engine is cold but when the engine is warm it will not even crank-all of the dash lights come on though. It has a new battery, new starter, new starter relay, new positive and negative cables. I've seen some other problems like this posted here but I can't seem to find a solution. Has anyone had a similar problem or have any ideas??
Old Nov 6, 2011 | 07:26 AM
skypilot's Avatar
Ignition switch. power to the soleniod goes through the switch. If you want just rig a new wire to send +B to the solenoid from a new switch inside the cab.
Drove me nuts too until I recalled the mantra of the 60's. +B to second on the coil, and a screwdriver on the starter. Off you go.......
Old Nov 10, 2011 | 04:11 PM
rfs002's Avatar
I appreciate the help. I put in a new ignition switch and it worked for a couple of times but now I'm back to the same problem. Drove around for a bit then shut it off, tried to start it and nothing... anything else it could be??
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
Michael oaks
Jul 27, 2015 11:47 AM
redneck17
Jul 17, 2015 07:44 PM
