1986 turbo,2.4l automatic with overdrive xtra cab
Old Jul 24, 2006 | 01:12 PM
tampabayota's Avatar
this truck runs but has no power.It has a 7 inch lifti dont know if it was re geared but driving this thing sucks right now any tips?
Old Jul 24, 2006 | 01:54 PM
anthony1's Avatar
I'd lift the rear and spin the tires. see how many round it takes for the d-shaft to spin in order for the tires to go one round. if it's a little more than 4 then you have 4:11 if 4 adn 1/2 then you have 4.56 if a little more than half you have 4.88.
It also help if you tell us the tire size.
Old Jul 24, 2006 | 06:23 PM
ironroad9c1's Avatar
more than likley though the turbo is bad, they burn through the exhaust part and then don't produce any boost.how many miles?
Old Jul 24, 2006 | 06:39 PM
mastacox's Avatar
We can also take a guess at your axle ratio if you could tell us how many rpm's your engine pulls at a specific speed and a specific gear (EX: 3000 rpms @ 70 mph in 5th gear). You also need to tell us what size tires you have (maybe measure with a tape measure too). It seems that if you have a 7" lift, you're going to have some pretty big tires on that thing, and it's hard to say if the axles have been re-geared.
Old Jul 25, 2006 | 10:54 AM
just look on the door jamb sticker and tell us the stock tire size also .they makes it real easy.
Old Jul 25, 2006 | 07:07 PM
they are 33" turbo works im gonna give it a real good tune up new injectors plugs wires look for any vacum leaks did a comp test all 4 cyls were at 130 thats good
Old Jul 26, 2006 | 02:56 AM
how do you know the turbo works?
you hook a boost gauge to it ,if so what did you get?
Old Jul 26, 2006 | 03:22 AM
no i went by the light on the dash and sound i havent gotten that far yet to check any help would be gratefull how do i check it
Backcountry411
Jul 24, 2015 08:06 AM
Robojd1
23
Jul 21, 2015 01:43 PM
hexrain
Jul 12, 2015 01:13 PM
Steezy96yota
Jul 6, 2015 10:00 AM
