16" Late rims on 1st Gen?
Old May 26, 2008 | 06:30 AM
Yopar's Avatar
Anyone running either steel or alum late model 16" stocker rims on a 1st gen?
Old May 26, 2008 | 07:13 AM
phildelfino's Avatar
I thought about doing that. My stocker rims were 5" of backspacing and I put 30x9.50x15 tires on with no problems. The used aftermarket rims I got have 3.75" of backspacing, so nothing will rub on the inside of the tire. the tires are 33x 12.50x 15 and they rub when turning (in the front wheel well, up against the firewall ). In the back I need a lift. These rims cause the tires to stick out about 3". They are a big tire and wheel combo. The rims are 15"x 10".
Moral of the story is whatever you buy, have less backspacing when going bigger. I reduced my BS by 1.25" and it was probably too much. I could have done less.
Old May 26, 2008 | 03:39 PM
slacker's Avatar
not mine , but a customers truck I did the body on a while back .. http://www.toyotafiberglass.com
running 16" for a while now , and no problems at all .
Old May 26, 2008 | 04:57 PM
michalik_piotr's Avatar
find my post about running 5 star rims off a limited....back space is wrong, had to get spacers and the inside diameter is wrong, had to grind out to fit over manual hubs.
Old May 26, 2008 | 05:42 PM
jjrgr21's Avatar
i'm running the 16" spare steelies on my 86
Old May 26, 2008 | 08:19 PM
BMC's Avatar
BMC
Im running 16 in stock steel tundra wheels with my street tires on them. Their 16x7 with a 5 in backspace. No problems at all.
Old May 27, 2008 | 07:56 AM
Yopar's Avatar
Thanks guys. The 16x7 steel are on my list, junkyard cheap and plentiful. Plan is to throw on some black paint and call it done. The 5" backspace sounds like a little much, but I guess if ya'll are running them and they work, that's all that counts.
Jun 1, 2021 01:51 PM
diingodog
Jan 11, 2018 10:39 AM
89fourrunner
Feb 17, 2016 06:52 AM
vanion2
Jul 29, 2015 06:17 PM
noahstancik
Jul 17, 2015 05:38 PM
