15 fuse continue to blow, over an again!!
Old Jul 9, 2016 | 10:45 PM
RAD4Runner's Avatar
Originally Posted by Turtl3
Try leaving the key off, put the multimeter back in the fuse position like u did before, then jump B+ to FP. That should give u a true reading on what the pump is pulling, and not whatever else is attached to the efi circuit is also pulling
To keep it simpler, leave fuse as it is, and use the multi-meter setup to jump B+ to FP. Meter will only read current to fuel pump and wires leading to it - including leakage to ground if there's any short.
Originally Posted by Charchee
...Sounds like a faulty new pump. I hate aftermarket electronics. I see issues with them all the time.
+1 For things that are necessary for safe running and operation, I prefer OEM.
Old Jul 14, 2016 | 12:41 PM
Diego toyota's Avatar
We got the Toyota fixed!! Yay!! We weren't able to find the root cause due to time constraints so we ran our own wires for the fuel pump via a relay. Now the truck runs. Thanks to everyone that helped trouble shoot this issue.
Old Jul 14, 2016 | 02:00 PM
scope103's Avatar
Originally Posted by Diego toyota
.. We weren't able to find the root cause due to time constraints so we ran our own wires for the fuel pump via a relay. Now the truck runs. ...
If you bypassed the COR (sounds almost certainly like you did), that means that if you get in an accident that breaks a fuel line, the fuel pump will keep spraying fuel while you're trapped in your seat. That will make that "time constraint" sound pretty unimportant.
Fix it correctly. Soon.
Old Jul 14, 2016 | 02:18 PM
wyoming9's Avatar
Back in the old days we never worried about electric fuel pumps shutting off
It was just the gas tanks catching on fire.
Then real life car fires are not near as impressive as in the movies
surf4life
Sep 19, 2016 09:29 AM
mac79
Jun 17, 2016 05:53 PM
geoduke
May 18, 2016 04:18 AM
foggybottom
May 16, 2016 02:56 PM
ProudDad
Apr 11, 2016 02:52 PM
