120amp Jaguar Alternator Upgrade **HOW TOO**
Old Mar 5, 2021 | 01:36 PM
  #81
Steven Bernard's Avatar
Originally Posted by chris514scott
No such thing as a stupid question... Yes the plug matches. That was one of the main reasons I went this route, that way i didn't have to mess with my harness or fab up a new plug.
This Alts are NOT the same size. The Jag is significantly bigger and heavier but the mounts are the same. This alt will barley clear the radiator hose because of its larger size, but it will clear.
I went with your suggestion, but my mechanic said the the plug is different?
Old Mar 5, 2021 | 01:59 PM
  #82
stanz's Avatar
Don't know what to tell you... mine was an identical plug and have ran it for years with no issue.
Old Mar 5, 2021 | 02:02 PM
  #83
stanz's Avatar
Post pics of the back of the alternator you picked up
Old Jan 31, 2024 | 05:18 PM
  #84
davefarr's Avatar
Bringing this back from the dead......regarding the internal voltage regulator mentioned on post 57- are guys just plugging this alternator in and going or are they replacing the regulator/plug assembly ?
Old Jan 31, 2024 | 06:49 PM
  #85
stanz's Avatar
It's plug and play... both alternators have the same Denso plugs and the terminals are the same. I only had to taper the pulley for it to go in.
Old Feb 1, 2024 | 04:42 AM
  #86
davefarr's Avatar
Are the terminals the same? my reading indicates that one terminal is dead/blank on the Jag denso...... is there no functionality loss (dash gauge?) or something.
Old Feb 9, 2024 | 08:09 AM
  #87
dfarr67's Avatar
S terminal, sense is deadheaded on the Jag alt. Internal sensing vs oem external.
muddpigg
Nov 19, 2017 01:19 PM
sploople
Feb 4, 2015 10:06 AM
chris514scott
May 24, 2012 10:09 AM
qdude79
Aug 5, 2010 05:07 PM
pattycakes77
Sep 9, 2009 08:10 PM
