1 Locker or 2 Limited Slips?
Old Jan 4, 2011 | 12:03 PM
wilshire's Avatar
ARB air locker in the rear vs Truetrac both rear and front. Seems that either setup would cost about the same. Which one do you think is better?
Old Jan 4, 2011 | 12:11 PM
mightymouse's Avatar
arb in the rear and you could get the front locker later.
Old Jan 4, 2011 | 12:26 PM
MB4runner's Avatar
Spool the rear. Spartan the front, I've been hearing great things about the Spartan. Probably for both you are around $500!
Old Jan 4, 2011 | 12:28 PM
blake.nemitz's Avatar
elocker rear and arb front if you have snow. driveing a front locker in snow sucks if you cant unlock it
Old Jan 4, 2011 | 12:29 PM
highonpottery's Avatar
x2 if the rig is going to see pavement. easier on the tires too.
Old Jan 4, 2011 | 12:37 PM
Junkers88's Avatar
x3....
Old Jan 4, 2011 | 12:52 PM
Bojangles's Avatar
x4.....
Old Jan 4, 2011 | 01:47 PM
peow130's Avatar
What we really need to know is what you plan to do with the truck.
if this truck sees alot of highway and onroad/snow, with very little offroad, id say f/r lsd.. if it sees purely offroad, spool rear and arb front.
if it sees a mix, arb rear, get another one later for the front.
Old Jan 4, 2011 | 02:00 PM
xxxtreme22r's Avatar
yup I vote for the ARB front/rear or LSD front/rear. If it were my DD and being in PA, I think I'd rather either of those two combos. Not sure If I would ever lock the ARB's in the snow though unless I was snow wheeling. Not sure how I would like both LSD's in the snow however, but they cannot be as bad as full time front/rear lockers.
Old Jan 4, 2011 | 02:25 PM
Duffdog's Avatar
I did supra LSD in the rear and detroit locker in the front. I also tightened the LSD, so it doesn't work very well in snow, but kicks ass off road without chirping the tires on road. did both axles with 529s for $800.
Junkers88's Avatar
Just an FYI. A full time locker in the rear is a pain in the snow and ice. I have lockers front and rear (Lock-rite and Aussie) and I've been in places where all four tires just turn and do nothing for forward movement. Having said that you might want to look at what tires you are running for traction. Mine are terrible in the ice and only less terrible in the snow but then again they are getting kind of slick. I would advise against LS diffs since you have to learn how/when to apply the brake to make the lifted tire decide to lock and put traction to the other one.
Lots of variables there but I still think with a good set of skins and the rear locked you'll go farther. Better yet to be able to lock and unlock the rear. ARB in the back is still my vote.
Old Jan 4, 2011 | 03:15 PM
85gijunk4x4's Avatar
just my oppinion, others may think different, but id go with 2 selectable lockers, get a rear arb now, then maybe get one up front later.
Old Jan 4, 2011 | 04:30 PM
Duffdog's Avatar
That only applies to gear type LSD differentials. Clutch type differentials (like the supra JZA70 type) are speed sensitive, meaning when one tire lifts off the ground you can get both tires to lock just by giving it gas. When one tire gets up to sufficient speed, the other tire immediately grabs and tries to pull you out.
Probably not the best option for low-speed rock crawling, however, as neither tire will ever get to sufficient speed.
Old Jan 4, 2011 | 05:30 PM
yodaLJ's Avatar
I would go with the ARB locker in the rear. Like others have said you can add the front later, having limited slip really limits your abilities.
Old Jan 4, 2011 | 05:53 PM
RustBucket's Avatar
I have dual Truetracs and I like it for moderate trail riding and the occasional butt-clincher obstacle. Great manners in snow and slipperies and in high articulation situations a little stab to the brake pedal makes it find traction. A rear e-locker is in the works though since that is undoubtedly superior for more technical trails.
Old Jan 4, 2011 | 06:25 PM
Rerunn's Avatar
If it were me...ME lol I would do an ARB rear and do a LSD front. Ride around with that, trail it and what not and see if you need the locker in the front. I think having atleast ONE locker would be better that 2lsds. just my opinion.
Old Jan 4, 2011 | 10:19 PM
4x4runr's Avatar
What kind of wheeling do you do? How often? DD? Is Money an issue? I will give you my best opinion with these questions answered. ARB is TOO expensive IMO.
Old Jan 5, 2011 | 02:17 AM
findley's Avatar
With all the talk about e-lockers. does anyone have a link to the axle length issues/ breaking the side gear...
thanks
TheBFA
Feb 15, 2020 06:55 AM
primordialbeast117
Dec 19, 2015 12:23 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
charlie_fong
Sep 27, 2015 10:06 PM
