Is Your Rear Pinion Seal Leaking?
Old Mar 21, 2010 | 04:36 PM
waskillywabbit's Avatar
Talking Is Your Rear Pinion Seal Leaking?
Does your gas tank look like this?
Does your rear diff look like this?
Does your rear diff look like this underneath?
Now if you are still not sure take out the rear pinion seal and compare it to a new one?
Yep, I think it was toast and needed replacing.
Took all of 30 minutes and no more leaking.
Old Mar 21, 2010 | 04:48 PM
toyota4x4907's Avatar
Jeez. I wish mine only took me 30 minutes. Mine was so seized in there I had to cut it out with a dremel and mini cutting wheel thing. I tried to muscle it out before. Took me nearly 3 hours to finally get it out!!
Old Mar 21, 2010 | 04:54 PM
toyospearo's Avatar
it takes 30min when you have air, impact gun, impact sockets, seal puller, seal driver, AC or heat, Regular visits from the Snap On tool truck etc. etc. etc.
Old Mar 21, 2010 | 04:56 PM
You guys don't have all these things?
Old Mar 21, 2010 | 04:57 PM
what? How would air tools make it so much faster. All you gotta do is drop the shaft, take off the flange and theres the seal. What was a PITA was the seal itself!
toyospearo's Avatar
Dude, times are tough!!
Old Mar 21, 2010 | 05:05 PM
4runnerRandy's Avatar
As a mater of fact mine does. It wont after I install the e-locker from a Taco I have sittin on the bench in the garage. And Wabbit we are all jealous of all the tools and nice shop that you have, at least I am anyway. by the way congrats on the shop.
Old Mar 21, 2010 | 05:16 PM
874runnersr5's Avatar
mmmm snap on truck.
Old Mar 21, 2010 | 05:32 PM
Thanks. Everybody has to start somewhere. I started with a small tool box, a welder and a Makita angle grinder.
Old Mar 21, 2010 | 06:09 PM
82blueyota's Avatar
if your pinion bearings are toast it will leak again i have replaced mine like three times in the last year now wile waiting to get my new thirds with 4.56 and my aussie in.just kept puttin new seals in to keep the oil down.gear oil mixed with mud is the hardest crap to get off.
plus the crappa seals suck. i can definetly see the diference in the oem seal.imo
Old Mar 21, 2010 | 06:13 PM
Diffs will have 5.29s soon regardless but it was a simple fix for now as the seal was clearly OLD OLD OLD.
jerusry
Oct 19, 2015 05:28 PM
andrewtexas123
Jul 14, 2015 04:29 AM
cars-guy
Jul 11, 2015 07:51 PM
jakebarrett
Jul 10, 2015 07:15 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
