Won’t crank no power to cab
Old Jul 23, 2020 | 11:48 AM
Notamechanic342's Avatar
I have a 85 pickup that I took apart the ignition on and now it won’t start. I started it with a screwdriver to get home after losing my keys but wouldn’t start back when I shut it off. It makes a single click in the fuse box when I turn the ignition but I can’t figure out why it won’t crank. Any ideas?
Old Jul 23, 2020 | 03:27 PM
RAD4Runner's Avatar
A problem well-stated is almost solved.
No power to cab? You absolutely sure?
Or just no crank?
Pls see signature.
Old Jul 29, 2020 | 10:52 AM
Fixed the electrical problem, now just won’t crank. I think starter is stuck I’m gonna try to bump it or get a new starter.
Old Jul 30, 2020 | 11:20 AM
2ToyGuy's Avatar
Read the thread Rad put up on the starter relay replacement. He has a method for testing to ensure the starter, and it's associated circuit to engage it to the engine, are still good.
Essentially, it involves running a wire from the battery down to the spade connector on the starter, and seeing that it cranks. Basically, you're bypassing all the other circuitry, and just testing the starter.
It WILL crank the engine, so only touch the wire to the battery very briefly, only long enough to test the starter, and ensure that the transmission, and transfer case, are both in neutral. Ensure there's no one in front of the truck. Not even close. No feet in front of, or under, tires.
Good luck!
Pat☺
jonniejiggles
Feb 21, 2016 01:29 PM
Jpeterson16
Feb 19, 2014 07:15 AM
914runnr
Dec 14, 2006 03:26 PM
colsoncj
Feb 8, 2006 02:04 PM
hardluck
Aug 4, 2004 01:12 PM
