What gear is in these rearends?
I just got/started workin on my 85 4cyl. I have heard that the ifs trucks have a 3 inch wider rearend. My parts truck is a 88 v6 4-runner. I was wondering if the stock gears are different? Thanks
If both are manual transmissions, likely the same. You can look up what came from the factory:
- http://www.4crawler.com/4x4/ToyVIN.shtml
Though I understand this is not always 100% accurate, if you remove the drive shaft frome the differential flange and look at the retaining bolt, you'll see it is painted. If the paint is pink, it's a 4:10........'n stuff
Here's some info
http://home.4x4wire.com/erik/diffs/
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
