What gear is in these rearends?
Old Oct 14, 2007 | 01:12 PM
ydopen's Avatar
I just got/started workin on my 85 4cyl. I have heard that the ifs trucks have a 3 inch wider rearend. My parts truck is a 88 v6 4-runner. I was wondering if the stock gears are different? Thanks
Old Oct 14, 2007 | 01:22 PM
4Crawler's Avatar
If both are manual transmissions, likely the same. You can look up what came from the factory:
- http://www.4crawler.com/4x4/ToyVIN.shtml
Old Oct 14, 2007 | 05:46 PM
fustercluck's Avatar
Though I understand this is not always 100% accurate, if you remove the drive shaft frome the differential flange and look at the retaining bolt, you'll see it is painted. If the paint is pink, it's a 4:10........'n stuff
ydopen's Avatar
the 4cyl is manual and the v6 is automatic Thanks for the info
Old Oct 16, 2007 | 11:55 AM
tiresrus's Avatar
Ive been told that some have 3:73 and 4:10.
Old Oct 16, 2007 | 12:46 PM
MudHippy's Avatar
Check the Axle Code on the information plate on the firewall behind the engine. The code starts with a "G" then three numbers.
G072,G074=3.90
G292,G294=4.10
G282,G284=4.30
G252,G254=4.556
G142,G144=4.875
Old Oct 16, 2007 | 02:04 PM
4runnerx3's Avatar
Old Oct 16, 2007 | 02:06 PM
4runnerx3's Avatar
Here's some info
http://home.4x4wire.com/erik/diffs/
Old Oct 16, 2007 | 02:34 PM
ydopen's Avatar
Awesome thanks for all the info.
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
