What engine is this?
Old Aug 8, 2006 | 09:06 AM
Sr5trd99's Avatar
Hey guys,
I just bought my self a 1985 4Runner and the thing is freaking awesome but right now im having diffeculty trying to figure out what parts are on it. The previous owner did a few modifications upgrading the brakes, V6 rear carrier and dual trans. The question that I have is with the oil pan. He said that he had the engine rebuilt 10K ago and the engine runs fine besides a oil leak, but there is a large dent on the pan cause by maybe a jump and the axle hitting the pan. I'm thinking the dent is causing the leak but why would the axle hit the oil pan? I ordered a new 1985 4Runner oil pan from the dealer ship and when I receved it was completely different. The lower hump was in front instead of the back side of the pan. The dealer double check the pan # and everything so im wondering if the motor has been swapped out with a different one. From what I can tell it's definitly a 22Re and the tag on the vehical says 22R-EC 2366cc JT4RNGIDXF5090220 Model RN60LV-MDEA. Here are some pictures of the oil pan. Is this a different engine, is it suppose to be like that and the dealer is giving me crap about the pan or what?
Thanks,
Kevin
Check under "Engine"
http://www.supermotors.net/vehicles/registry/15209
Old Aug 8, 2006 | 10:01 AM
RustBucket's Avatar
Definitely a 22re... that is a weird looking pan. Most of them have only two levels, and the lower part is neat the back of the engine.
Old Aug 8, 2006 | 01:37 PM
Sonofmayhem's Avatar
C stands for california smog. good truck, my 85 pickup had the same engine.
Old Aug 9, 2006 | 09:06 PM
Ditchpig's Avatar
The 20R and 22R/RE have the same oil pan, but they are 4WD and 2WD specific!! The 2WD oilpan has the hump closer to the front/middle. Make sure that if you have a 4x4 you reorder a 4x4 pan. That's what it sounds like happened here, you got yourself a 2WD pan for the 22R engine.
Old Aug 10, 2006 | 07:09 AM
Sr5trd99's Avatar
So does your oil pan look like this one?
Thanks,
Kevin
Old Aug 10, 2006 | 07:12 AM
Sr5trd99's Avatar
I think the prevous owner swapped out the front springs for the rear springs and put chevys in to the rear. Could this have re located the front axle causing the axle to hit the oil pan?
Thanks,
Kevin
Old Aug 10, 2006 | 07:21 AM
kyle_22r's Avatar
that's a 2wd or celica pan. definitely not that way from damage -- they probably pulled the motor from a 2wd truck and dropped it in without putting on the correct oil pan and pickup.
Old Aug 11, 2006 | 12:41 PM
ToyotaGuru's Avatar
2wd
The sump on the middle is for Celica's. The sump for the 2WD is in the rear
like the one you got. If you need the correct one let me know. I have the pickup also. I have seen several smashed 2WD pans from the solid axles.
Old Aug 14, 2006 | 03:47 PM
Sr5trd99's Avatar
Ok guys,
Over the weekend I took the pan to a toyota dealer and the told me that the pan design has changed. My oil pan is like one from a 1984 toyota pick up with two steps and no skid plate. If I wanted to change it to a 1985 4Runner pan then I would have to get a "kit" to convert it over. I guess the "kit" has all the parts for a new pick line and everything. I think im just going to put some bigger bump stops under there to solve the problem.
Thanks for the help,
Kevin
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
