weber Trans-Dapt adapter from Summit
Old Jan 30, 2014 | 02:34 PM
mikeyd6789's Avatar
I used this adapter plate with my weber. But its alot taller than the weber adapter plate so the linkage is not tall enough now. Does anyone have any experience with setting the linage up using the Trans-Dapt adapter from Summit?
Old Jan 30, 2014 | 05:26 PM
JonnyBoy's Avatar
Really dude? My answer on your last spacer thread wasn't clear?
You need to space the throttle linkage up with spacers and longer bolts. Do you have the original cast 2 piece adapter? If so, there should've been some spacers for the throttle linkage included. Take the total height of the 2 piece adapter and subtract the height of the small spacers from that. The number you get is about how much shorter your spacers for the throttle linkage now need to be for the taller Trans-Dapt spacer.
Old Jan 30, 2014 | 05:57 PM
mikeyd6789's Avatar
OK just wanted more details.
Old Jan 30, 2014 | 11:33 PM
JonnyBoy's Avatar
Sorry if I came across like a jerk, something's always lost in translation so to speak over the internet. I read that again and would probably think I'm a jerk if I were you. Generally, if you want more clarification, it's easier to post again in the original thread rather than starting another, though.
I don't think I have any pictures of my old weber that would show the spacers under the throttle linkage, but it really is just as simple as spacing it up. I used the LCE spiral bore adapter, and from what I've seen so far the Trans-dapt adapter is taller. The linkage spacers for the LCE adapter had to have been at least 9/16" so you may need something in the 3/4" area. Just a guess though, really.
Old Jan 31, 2014 | 04:33 AM
mikeyd6789's Avatar
Haha its alright..thanks for all the info. I'm new to forums so any advice is good advice. Thanks for all your help. Going to measure and buy some spacers today.
Old Feb 9, 2014 | 11:58 AM
mikeyd6789's Avatar
Alright still working in this weber ( I work alot ..hard to find time). This trans dapt adapter is about to drive me nuts. My question is...what is the 4th hole in the adapter?? Do I plug it up? Do I plug something into it? The pic may help
Attached Thumbnails weber Trans-Dapt adapter from Summit-screenshot_2014-02-09-15-53-34-1.png
Old Feb 9, 2014 | 01:38 PM
mikeyd6789's Avatar
Never mind!....found it...i gotta plug it up.
Old May 7, 2020 | 02:51 PM
YotaSquacth's Avatar
Exclamation Helllllp
6yrs later lol do you happen to remember what number you came up with on the spacers? im in the process of doing this now and cant find any info on this but this old thread.
Old Jun 12, 2020 | 03:50 PM
msane99's Avatar
Spacers for throttle linkeage
Two spacers high. The ones that come in kit about 1" high. I bought a piece of straight aluminum pipe and cut for second one. I beleive 8mm inner diameter.
This is on late model 20r intake (1980)
This in on a 20r intake early model (late 70's)
zanzabar0
Oct 11, 2015 02:56 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
