Irab88
Stock is fine if you already have a V6
Is yours a V6 with the V6 calipers, dual booster, 1" master and vented rotors? What year is your truck and will the parts from yours fit mine?
Thanks
Nope. 22R-E from the factory, no brake upgrades at all, 5VZ-FE swapped in (see signature)
But I misread your year. You may want to upgrade if what you have isn't enough. I know they gradually increased stopping power as the years went on.
irab88
Thanks, I think while i'am doing this I will upgrade the brakes in the front, if only I could get some straight answers from the people who have done the upgrade.
Seems like I need:
dual booster
1" master cylinder
V6 calipers
vented rotors
All of which can be from a V6 89-95 4 runner.
I looked at a thread that dropzone posted in his stickey's "notebook for ideas" for links to other web sites about brake upgrades that have this information and this is what I ended up with
Sure wish he would comment on what I have here to see if I'm on the right track
I wasn't going to do the upgrade but have since decided to go a bit bigger on my wheels to 35s
the arm/rod turns the valve/bolt. The bolt adjusts the pressure..
I don't recall off hand if it's a valve body on a spring or a needle valve its adjusting but the effect is the same. Arm moves up relative to the valve body the valve/volt moves inward and routes more to the rear lines.
ok, making more sense
Do you know how I can check the valve to see if it's working?
Here are the pics
It's out of the truck and I'd like to check it out to see if it works properly.
Many ppl simple tie the arm of the LSPV up so it is in the most open position all the time, I did this for years. Some have cut arm off and use a turn buckle to "adjust" flow to back brakes. Is a guy on pirate that machined brass pieces to make LSPV a manual proportionate valve.
I have not troubleshot LPSV to verify function.
muddpigg
See the problem I see where people just tie it up is that you "might" get to much braking power to the rear wheels causing the rear wheels to lock up and cause "fishtailing" I would rather have it work the way it was designed allbeit maybe not the best design to start with. Next would be a way to adjust it so as to regulate the pressure. I still don't know how to check the valve when it's off the truck.
muddpigg
The tests are in the book, you can't do them off the vehicle without a way to apply and measure the hydraulic pressure. Best you can manage is to try checking the flow while you manipulate the valve rod, need some form of pressure tank, catch cups, measuring device..
NY - I get what you're saying. My comfort on working on and changing from stock have greatly changed from 12 yrs ago.
I've never seen "how to" a LSPV function test. You could test it by measuring flow rate. So bleed all air out of the system then change height of LSPV arm, but get a baseline in either up or down, then measure amount of fluid (quantity) that can be bled off a rear cylinder on a single pedal stroke. Fluid quantity should change with arm height adjustment. Will need a to be able to measure small quantity. Maybe a syringe would with CC/ml scale with just enough brake fluid in it so no chance of air slipping into brake system. Us medical types call it "bleeding the the line."
I fully understand concerns of fishtailing from rear brakes locking up under heavy braking. Makes me cringe every time I see a member posting how the removed the LSPV and do not run a manual proportionate valve. With disc brakes rear I run the manual valve just above the lowest setting. How I set it was find a relative safe straight away and hit the brakes hard. Then adjusted accordingly, I did want any surprises when a hard braking situation came up while regular driving rig. You can do the same means of "adjustment" with tying up LSPV if you decide to go that route.
Yeah, i saw that. I was just hoping someone had a different way to check it
Thanks
muddpigg
Thanks also, I guess I'll figure it out when the rear end if done and put back in.
Thanks
