turns over.. kinda
Old Jul 26, 2008 | 05:51 PM
algranger's Avatar
turns over.. kinda
im sure this has been asked before but i couldnt find anything so here it goes. i just got a truck with a 22r that the guy says wont start, i got it home and tried to start it and when it turned over it didnt sound normal it was more of a smooth rotation, the engine was turning but it sounded like maybe there was no compression or something?
any ideas? im guessing its timing related
Old Jul 26, 2008 | 06:21 PM
bigt's Avatar
is it getting spark?? do you have a compression gauge??? is it getting fuel???
cann you start it putting fuel in the carb???
Old Jul 26, 2008 | 06:22 PM
myyota's Avatar
Pull the valve cover and check the timming chain and guides.
Old Jul 26, 2008 | 06:35 PM
algranger's Avatar
has spark, has fuel, no compression gauge but im sure a friend has one..
Old Jul 26, 2008 | 06:36 PM
algranger's Avatar
do i need to remove the bolts in a pattern? should i get a new cover gasket if im gonna pull the valve cover?
Old Jul 27, 2008 | 09:54 AM
85toy's Avatar
i dont think there is a pattern but it is recommended that you change the gasket even if its not leaking now it will after it is removed.
Old Jul 27, 2008 | 10:36 PM
rowdy235's Avatar
my friend bought a chevy with little compression one time and no kidding all the valves were adjusted so tight it wouldn't have enough compression to start. 15 minutes and it ran like a top.
LosPatosDelSur
23
Mar 12, 2021 03:08 AM
jetpilot
Aug 15, 2015 06:48 AM
maddogd
Aug 9, 2015 04:32 AM
Dakotaneu
Jul 27, 2015 12:03 AM
Hamonacracker
Jul 17, 2015 08:33 AM
