Truck shimmy shake
Truck shimmy shake
About 55 mph the steering wheel shakes hard.....not until then and about 60mph it goes away.... IDEAS? I was thinking a wheel out of balance, but not a mechanic.
Thanks
Woody
Thanks
Woody
This happened on my 1993 Camry for its entire life - shook from 65 mph to 70 mph, nowhere else. My family has been going to the same Toyota mechanic for 30+ years (parents went before I was even born) and he was never able to figure out why it did this.
I have noticed that my 1994 Pickup does this as well, but not all the time. It is usually around 65 mph as well.
I think I remember watching a 'Trucks' or '4x4' episode on the power block relating to the Jeeps 'Death Wobble'.
It had to do with a lift kit changing front suspension geometry.
Just a thought. I had a friend with a Gen 2 4runner that did that simply because he put big tires on it and kept the factory suspension.
Prob not your problem but its an idea of something to look at. I'm sure the more experienced rock crawlers would know for sure how you could tell if the geometry was way off.
SA Toyotas are also prone to Death Wobble. Root cause to be anything from a bad steering box, worn Tie Rod Ends, Spring bushings, wheel bearings, trunnion bearings, wheel out of whack, out of balance tires..and I am sure I missed a couple of things...
Just noticed, Should prolly move this to 86-95 since it's a 87. Checked shackle bolts no difference, moved tire no difference. did notice bolt on front steering arm loose, but tightened and no difference, might be giving in soon and taking to mechanic! Anyone know any in rochester mn?
YotaGreenhorn
Jun 27, 2015 07:00 AM
LV_4Runner
16
Aug 5, 2002 11:35 AM
