Throttle help with 34/34 weber carb
Old Jan 15, 2011 | 12:13 PM
BTX58's Avatar
Installed carb and have it running pretty good but when i punch the gas it doesnt return the throttle back downn to idle. Do i need a stronger return spring and where can i find one at.
Old Jan 15, 2011 | 12:18 PM
xxxtreme22r's Avatar
you might, I did with my 32/36. But also make sure the cable is not getting bound up in on the linkage. ie jumping track. If so then the cable is either too tight or the bracket on the valve cover is bent a little.
The springs you can get at any auto parts store. It's up to you to figure out where you want to mount the spring. This will determine how long the spring you will need etc etc. Don't get too thick of one though as your throttle will become very stiff. When I did mine I wired the spring under the linkage and then to near the vacuum line assembly by the valve cover.
4.34runner88
Feb 7, 2016 02:24 AM
user 82300
Jan 19, 2016 02:01 PM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
bhaithc
Sep 17, 2015 07:53 PM
