What do I do with this? Weber 32/36 conversion stuff
Old Jan 3, 2011 | 03:30 PM
84YotaBuck's Avatar
What do I do with this after a Weber conversion? Had it on for a few years since I switched to the Weber, otherwise oil goes everywhere. Can I just remove it and fab up a block off plate? What have other done? It's part of the Emissions crap and no longer has anything going to it.
[IMG][/IMG]
Slowly getting things back together after blowing a head gasket. Getting a new head, the old one is too thin and I don't want to use a shim. Pulled the pistons to re-ring it, have horrible blow by, only 25k on the rebuild. Every top ring was broken, how the hell does that happen? Going to run a dingleberry hone through the holes before putting the pistons back in, don't have any crosshatch left, glazed over holes, at least it's nice and shiny!
Old Jan 17, 2011 | 01:45 PM
84YotaBuck's Avatar
Well, since nobody replied, here's what I found. Just block the damn thing off. Of course, that was after I already had everything back together, just a PITA to get to with the carb. on. Maybe I'll make something cool looking to put there in the TIG class I'm taking.
Old Jan 17, 2011 | 02:12 PM
xxxtreme22r's Avatar
for now I still have mine on there. If I had seen the thread, I would have definitely replied.
LCE has a block off plate for that EGR valve. But you can make one out of an electrical box cover as well.
user 82300
Jan 19, 2016 02:01 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Papadeath
Sep 14, 2015 10:26 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
