Tailgate Release Cables
Old Jul 27, 2012 | 07:46 PM
rokblok's Avatar
There are a few 2nd gen Runners in Augusta also....
Old Jul 28, 2012 | 06:25 PM
wavekayaker's Avatar
Rokblok, I've been to the pull a part there a few times, but saw another place while I was working in Augusta a few weeks ago. Ever been there? Decent?
Old Jul 28, 2012 | 06:51 PM
fiat128's Avatar
Here in Canada, they want 70 bucks a piece for those cables at the dealer. I tried all the bike shops with blank stares in return. Finally, I went to the pick-and-pull and found 5 cables from a couple second gens along with the steel window clamps. They work perfect, have the rubber ends to keep water out, and cost me $4.00 for everything.
Old Jul 28, 2012 | 08:29 PM
rokblok's Avatar
Southern pick a part? Off Doug Barnard? It's ok. Not a massive selection of Yotas, but generally have a couple 3rd gen Runners and a taco or two. Rarely is there anything older. Augusta Pullapart has older trucks/Runners more often.
Old Jul 31, 2012 | 10:39 AM
  #25
3YLSYKR's Avatar
Originally Posted by Lukifer
I wish I had just fixed the old set, but after a moment of stupidity they became totally un-fixable... Anyway, got the new cables, the new ones will probably last a lot longer.
Where from? Part numbers?
Old Jul 31, 2012 | 02:45 PM
  #26
junk4u's Avatar
Okay, I have been playing around with the idea in my head for a few days and looking at the internet. Here's what I come up with if you can get the parts.
Start out with some Bicycle Cable
Then some cable housing what bikers call conduit.
Once you get the right length cut and set you have to put what the bikers call a ferrel on the end of the housing.
Once the ferrels are in on each end of the cable, you can use a adjuster to lock it in place as with the original one on each end.
To finish off you need to put a barrel on each end.
Just solder the cable into the barrel as you can see the hole is kind of a coned shape so when you fill it with solder the cable wont slip back through.
Remember its just an idea right now.
Old Aug 6, 2012 | 02:47 PM
  #27
fiat128's Avatar
There you go. That looks pretty good.
Old Aug 8, 2012 | 01:31 PM
  #28
ErikJeanna's Avatar
These can also be had for about $5/ea at a boneyard...
kawazx636
Oct 6, 2021 03:03 PM
I8URSVT
Mar 2, 2021 06:23 AM
Truckwithoutaname
Oct 3, 2015 03:41 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Rcbc92
Sep 26, 2015 03:00 PM
