tachometer check
Old Aug 22, 2006 | 06:04 PM
meap's Avatar
tachometer check
Guys, I need help doing a tachometer check. I just installed it over the weekend and I'm not sure it's working right. I did make sure it's on the 4 cyl mode. I have a 84', 22R, 2 wheel drive, 4 speed trans with no major modifications.
I'm getting:
2500 rpm in 3rd gear at 40 mph and
3000 rpm in 4th gear at 65 mph.
It just doesn't sound right. . . it sounds like the engine is screaming compared to the rpm values.
If someone could help me out . . . .I would greaty appreciate it!
Old Aug 22, 2006 | 07:53 PM
4Crawler's Avatar
Plug in the gear ratios and tire size and find out:
http://www.4crawler.com/4x4/4LoCalc.shtml#FindRPM
Old Aug 23, 2006 | 11:25 AM
DudeBud's Avatar
I'm getting:
sounds close, i know that im my wifes 88 at around 70 in 5th its cruzing about 3000rpms
Old Aug 23, 2006 | 12:47 PM
rdlsz24's Avatar
I'm also at around 3k rpm at 70 with my 22RE.
Old Aug 23, 2006 | 03:51 PM
meap's Avatar
That web site is awesome, too bad I have no idea what my gear, rear or transfer case ratios are.
Is there anyone else that has a four speed trans, 22r that can help? I'm dying to know if this things is working right.
Old Aug 23, 2006 | 03:57 PM
meap's Avatar
I do know . . . I have 26" outside diameter tires
Old Sep 5, 2007 | 07:33 AM
deserttoy84's Avatar
the older 22r motors always sound like there gonna explode when they rev out but they dont of course. My friend has the newer 22r(carb also) with the sqaure valve cover; he revs it to 5 or 6k without making any noise.
Old Sep 5, 2007 | 07:38 AM
4Crawler's Avatar
T-case is 1:0 (1.00) in high range.
Axle ratio is likely listed on your VIN/Model info plate:
- http://www.4crawler.com/4x4/ToyVIN.shtml
4-speed gear ratios:
- http://www.marlincrawler.com/htm/tra...n/l_series.htm
Blamalam
Mar 12, 2022 07:34 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
raptor510
Aug 19, 2015 02:15 PM
calderp
Jul 27, 2015 09:58 AM
