T-Case help!!!!! Marlin 4.7 gears
Old Apr 5, 2009 | 11:10 AM
1990arizona4runner's Avatar
1985 4Runner 22re w/ manual transmission
I just had Marlin 4.7 gears installed in my t-case and am now trying to connect the t-case to the transmission but it won't line up. The 4WD shift rod coming out of the front of the t-case is hitting the transmission wall. This causes the t-case to be shifted counterclockwise and 1/8 inch and the bolt holes won't line up. Also the t-case will then not shift at all. Any suggestions? I have attached some picks to hopefully help.
Attached Thumbnails T-Case help!!!!! Marlin 4.7 gears-photo.jpg   T-Case help!!!!! Marlin 4.7 gears-photo2.jpg
Old Nov 7, 2013 | 09:31 AM
Gettinstarted's Avatar
1985 toyota won't go into gear
I have an 85 yota truck that I just traded my runner for and after a day of driving it, It will no longer move. I drove it up a steep grade and after about 5 miles it will no longer drive. It goes into gears without the clutch pushed in at all and doesn't grind. Even when in 4 it doesn't go anywhere, if some one on yota tech could help me out asap I would appreciate it.
Old Nov 7, 2013 | 09:41 PM
rokblok's Avatar
Most likely a dead clutch. Marlin clutch kits are awesome.
Less likely, a broken input shaft on transmission, but I presume you didn't hear any grenading before it quit? Input shaft breaking isn't common and should make a nice, loud noise....
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
priest16
15
Aug 6, 2015 07:43 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
SMOD
Jul 23, 2015 10:29 PM
