stripped thread on front spring hanger bolt
ok, so i was working on changing my passenger side front leaf pack cause there was a broken leaf in it.
i managed to damage the threads on the bolt for the front spring eye. now what do i do?
its not just a standard bolt, it has that stupid flange thing.
i cant figure out what thread it is, but if someone knows i might beable to repair it with a die.
or im thinking i might be able to weld a plate with a 1/2" hole in it over the large hole for the flange and just use a standard bolt.
either way im open to sugestions
thanks
thanks
think i could drill out the bolt from the flange and use a 1/2" bolt?
i dont have a drill bit bigger than 1/2" haha and my drill is only a 3/8 chuck so i dont think ill find a bigger bit with that size chuck.
and ya, m14x1.25 seems to be the right one, but i dont have a die for that size
there is a sleave in teh bushing, its ment for a 14mm bolt, a half inch bolt is 12.5mm as far as i know. im thinking thats what ill do for a temperary fix till i can find a 14mm bolt thats long enough.
Oh yeah, forgot the sleeve in the '84/5 spring bushing, '83 and older have none. Suppose 1/2" would work for a temp. fix, probably would not want to drive it fast or take it off-road like that. You can use a 9/16" bolt in place of the 14mm, they fit just fine and are 100x easier to find.
look up spring pin on google. it will come up with a site that has that for the fj. didn't dig through the site to see if they carried any other ones. the fj one was 20.00 each.
i feel you, i am looking for the center spring pin, as i am taking one of the leaves from my pack.
i dont really have the time to wait for an orderd bolt, or the money right now.
what i ended up doing was cutting off the old bolt, and drilling out the flange thing at welding school where i did my C level course.
put a 9/16 x 4 1/2" grade 8 bolt in it and it seems to work perfectly.
i figure id call that fixed right.
torqued everything down and drove it to work. seems to ride a little better without a broken leaf in the pack, not to mention safer lol
thanks for the all the help. im definatly going to stick around this forum
Best fix, when you have the time, is to cut off the stock spring hangers (if they don't tear off on their own) and make yourself a new hanger set up for regular bolts:
http://www.4crawler.com/4x4/CheapTri...ringHangerDrop
Jun 1, 2021 01:51 PM
toyoda8488
Jul 5, 2015 10:18 PM
