Starting problem
Starting problem
So I have a 1985 pickup with a 22r and the problem is the motor will run good but will only crank if you hold a rag over the top of the carb. Won't crank own it's own unless you do that. I don't know alot so any help would be appreciated
sounds like acc pump is bad or the passage is plugged. look down the top of the carb with the engine off and work the throttle, there should be a squirt of gas when throttle is opened . if the choke is working it should start cold but not after the choke opens. that is if the acc pump is bad.
if it is not a strong stream it still could have a restriction . you can remove the acc pump and hold the diaphragm up to light and look for a pin hole. it is on the passenger side of the carb ,it will have a leaver on the cover to operate the pump .it has four screws holding it on. if it looks good shoot carb cleaner through the passage to make sure it is open.
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
