stalls while warm
Old Dec 11, 2008 | 06:31 AM
frankentoyota's Avatar
stalls while warm
ok i have just got my new motor in and have had some troubles with it.. as i go down the road it randomly stalls when warm if i let off the gas at all.. i normally drop the clutch and it fires back up. but the other day i idled around a corner and it stalled and wouldnt fire back up. i got a ride home and went back in about 10 minutes and it fired up after a couple tries of cranks. It runs pretty good and idles alright while cold. it also seems like its being held back while accelerating and backfires when decelerating.
Old Dec 11, 2008 | 05:32 PM
t_boneshacone's Avatar
wow my truck does the EXACT same thing, i would really like to know also
Old Dec 13, 2008 | 08:52 AM
pcmentor's Avatar
Is the warm idle speed to factory spec? 750 or 700?
Old Jan 19, 2009 | 02:29 PM
PDX_1ton's Avatar
I have the same troubles right now. I have a 22re. For me the warm idel is set correct. My problem showed up after I pulled the valve cover to recheck the head bolts. When I put it back on the issue showed up right away. All the vaccum hoses are in place. I check and somebody else checked. Anybody have ideas?
Old Jan 19, 2009 | 02:33 PM
darksoldier313's Avatar
did u put a new gasket on the valve cover??
Old Jan 19, 2009 | 02:41 PM
PDX_1ton's Avatar
It has a newer gasket on there less than 400. I have never needed to change it before.
Old Jan 19, 2009 | 02:44 PM
just the first thing that comes to mind a vacuum leak do u have a vacuum guage hook her up c what she says
Old Jan 19, 2009 | 02:46 PM
PDX_1ton's Avatar
No vaccum gauge. Do you know hot to test for leaks?
Old Jan 19, 2009 | 02:52 PM
the guage would b the easiest thing and if u have one of those mini torches u can spray a small amount of propane around the area that might b leaking if it bogs down or revs up u got a leek also u can use certain starting fluid but b careful these items r flammable id go rent a vaccum guage or pick one up there not that expensive
Old Jan 22, 2009 | 07:06 AM
PDX_1ton's Avatar
Problem solved. The air intake hose/pipe which connects to the Throttle Body was not on tight. Someone pointed out that if air leaks in after the MAF sensor it will throw off the fuel/air ratio once the engine is warmed up.
Davebarbier
Nov 3, 2015 03:28 PM
gentry
Sep 28, 2015 06:16 AM
charlie_fong
Sep 27, 2015 10:06 PM
taraf
Sep 25, 2015 02:57 PM
bhaithc
Sep 17, 2015 07:53 PM
