Ruf?
Old Sep 6, 2008 | 10:02 PM
SpecialScottie's Avatar
Ruf?
Is it possible to run rears up front with the budbuilt banana shackles and just use a driveshaft spacer?
Thanks
Old Sep 7, 2008 | 09:30 PM
bump bump
Old Sep 7, 2008 | 09:42 PM
Tofer's Avatar
Sponsor
a little more information would be helpful.....
Old Sep 7, 2008 | 09:46 PM
Mic09dcsm's Avatar
Or get a long travel DS from Downey.
Old Sep 7, 2008 | 09:49 PM
Mic09dcsm's Avatar
I just checked those shackles out, couldn't the front DS compensate for how little forward they would move with these shackles and the stock front mount?
Old Sep 7, 2008 | 10:22 PM
http://www.budbuilt.com/new/shackles.html
Has anyone run RUF with the stock driveshaft and a spacer?
I plan on doing this to an 85 4runner
Old Sep 8, 2008 | 04:11 AM
WFO's Avatar
WFO
http://www.pirate4x4.com/forum/showthread.php?t=265669
Everything you need to know is here.
Old Sep 8, 2008 | 05:37 AM
4Crawler's Avatar
I initially ran my rear springs with only 2" longer than stock front spring shackles on my '85:
- http://www.4crawler.com/4x4/4R_suspe...II.shtml#Front
You could lengthen the front shaft with a spacer, however, the larger issue is that with the added travel (droop) of the rear springs, you'll likely pull the stick slip yoke apart unless you run limit straps. You need something with 6"-7" of slip up front with the rear springs.
Old Sep 8, 2008 | 01:11 PM
Hey 4crawler, how did you mod your front driveshaft for use with RUF?
Old Sep 8, 2008 | 01:37 PM
4Crawler's Avatar
I had a shop rebuild the stock shaft and lengthen it and add a long travel slip yoke to it. All off the shelf parts in it.
Old Sep 8, 2008 | 06:04 PM
Thanks.
How much should I expect to pay to lengthen and long travel my Driveshaft?
Old Sep 8, 2008 | 06:46 PM
4Crawler's Avatar
I've generally paid around $300 with a useable core shaft. Highangledriveline is one place to look or check for a local driveline shop. Lengthening cost varies as it depends on how long you need the shaft to be. To lengthen, you generally cut off all the tube and re-tube with new material, so adding 2" doesn't mean you only buy 2" of new tubing, you might be buying 20" or whatever length the shaft needs to be. Or do a square tube shaft:
- http://simbur.com/toyota4runner/drive_shafts.htm
Old Sep 9, 2008 | 01:18 PM
Has anyone run a square driveshaft on a daily driver?
How bad is it?
Old Sep 9, 2008 | 01:52 PM
4Crawler's Avatar
How bad is it?
Up front, you likely would have your front hubs unlocked and t-case in 2H, so makes no difference what kind of front shaft you have as it will just be sitting there.
Old Sep 9, 2008 | 06:11 PM
Right on.
Thanks again 4crawler
Old Sep 9, 2008 | 06:44 PM
dropzone's Avatar
Fossilized
Keep is mind that if you use your 4x4 during the winter (IE: driving to a ski resort) at more than 20 mph or so square driveshafts have a tendency to vibrate like crazy. Part of the expense of having a Drive shaft shop do the work is that they (should) balance the shaft.
Old Sep 10, 2008 | 01:03 PM
Is there anyway of balancing a square tube driveshaft?
Old Sep 10, 2008 | 01:09 PM
4Crawler's Avatar
Sure, probably need to take it to a drive line shop and have them spin it up in their balancing lathe and weld on balancing weights, assuming they would be willing to do that.
Old Sep 10, 2008 | 01:12 PM
ryantowry_81's Avatar
the hard part about balancing the square shaft is the inaccurate tollerance in the slip caused the drive shaft's geometry to change as the drive shaft spins. so unless you can get thet thing really close tolerances balancing wont do anything
Old Sep 10, 2008 | 05:33 PM
Tofer's Avatar
Sponsor
Originally Posted by ocdropzone
Keep is mind that if you use your 4x4 during the winter (IE: driving to a ski resort) at more than 20 miles per hour or so square driveshafts have a tendency to vibrate like crazy. Part of the expense of having a Drive shaft shop do the work is that they (should) balance the shaft.
not always the case... i have a square front drive shaft. it vibrates a very little bit between 45-55mph and then smooths out again by 60. when i bent my rear drive line and had to drive it home in front wheel drive it was smooth sailing even at 70mph. my only complaint about it is that if you have the hubs locked but not in 4wd, or your in 4lo and dont have the hubs locked, it makes a clanking noise. other than that no problems.
justdifferentials
14
Jun 11, 2017 08:36 PM
live4soccer7
May 11, 2016 06:52 PM
I8URSVT
Jan 15, 2016 07:25 PM
Toys4parts
Sep 26, 2015 01:56 PM
I8URSVT
Sep 3, 2015 11:42 AM
