rough ride
rough ride
i have an 85 straight axle with a 3 inch rough country lift and 2 inch lift shackles and it does okay on the road but when i go off road or in a field i cant stand to get out of 1st gear in 4low or other wise it beats the crap out of me i no its a straight axle but is there anything to help it?
thanks ahead of time
Pro Comp has a good kit, or Marlin, Trail Gear, All Pro all make great suspension kits. I currently run 3'' procomp lift in the front and 4'' in the rear (4runner top is heavy) and on the street it is bumpy because I have really poor shackle angle right now. On the trail, I run 10 psi and it isn't bumpy at all.
..as a data point, we just put a TG 5" rear spring kit under my buddys 94 4runner. Cut out all the factory 4-link junk (he trashed the whole rear suspension) and swapped in the TG kit, and it seems to be very flexy and soft.
Good luck,
C
Good luck,
C
i have another question does the stock front leaf springs have more or less leafs than the rear and also would stock springs have more flex and better ride than this rough county lift i have? thanks again.
Just a thought but did you put the shocks on the right way? They have to be installed the right way or the valving messes up and the shock may not be doing anything at all...
zytra
Jan 24, 2019 03:16 PM
Brodetski
Sep 30, 2015 11:50 PM
