rear heater removal
Old Jan 12, 2009 | 05:52 AM
littlecommando's Avatar
rear heater removal
so, i er, kinda went swiming in my 4runner and all my carpet is soaked with mud.
i took out the very front carpet, but i cannot get the passenger carpet because of the rear heater
i took all the bolts out but there are two pipes going to it. i cannot figure out how to get these pipes off without a hack saw. how do i get these off so that i can easly put them back on?
also, what is coming through these pipes? and will it hurt anything if they are not conected when i drive around for a week or so?
thanks for the help
oh, and i did search but i couldnt find what i need
Old Jan 12, 2009 | 06:06 AM
nv4runner's Avatar
I'm not sure how to get the pipes out, but they probably have engine coolant running through them to supply heat to the rear heater. As long as you cap them off, or put a hose going from one to the other (better option) you should be able to run without the heater for as long as you want. I've got a rear heater, but I have a second gen 4runner.
Old Jan 12, 2009 | 06:07 AM
4Crawler's Avatar
There are two rubber coolant lines hooked to those pipes, access from below (I modified mine with some elbow fittings):
Coolant runs through those lines, you'll need to loop the two lines to each other either at the heater or up at the firewall:
Old Jan 12, 2009 | 12:00 PM
thanks for the help guys, but i just cut the carpet in the middle so that i didnt have to take the heater out
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
msane99
Jul 17, 2015 10:13 AM
the1998sr5
Jul 16, 2015 06:20 AM
icentropy
Jul 14, 2015 10:23 AM
